Project Satin Black - Help!!!!!!!!
Purplebargeken
Re: Project Satin Black - Help!!!!!!!!
#76 Post by Purplebargeken »
Recessed? Not the right headgasket?
Arsebiscuits. What gasket do I need??
Bugger, bugger, bugger. At least it isn't all torqued down.
Purplebargeken
#77 Post by Purplebargeken »
I've emailed Mick Dolphin re: the correct headgasket set, rad hoses, thermostat and water pump gasket. Fingers crossed!
Jod Clark
#78 Post by Jod Clark »
Jeronen is right, that engine will have no compression if you continue with that gasket :(
#79 Post by Jon Tilson »
Good spot Jeroen...beat me to it.
I was gonna ask this question too...so glad you caught it before it all went pear shaped.
Purplebargeken
#80 Post by Purplebargeken »
Thanks hugely to the eagle-eyed folk who spotted the difference.
Does anyone have a piccie of the appropriate head gasket or a part number for one. Mick D is also puzzled as engines with this prefix are seemingly non-recessed and he is the one asking for the number. Just glad that it was spotted before I had bolted everything up. That would have been quite annoying.
Cheers :D
Ken
Edin Dundee
#81 Post by Edin Dundee »
This forum rocks!!! :D :thumbsup:
Purplebargeken
#82 Post by Purplebargeken »
Indeed it does!
Good bloke that Mick Dolphin. He has most of the important bits (including the head gasket). Whoohoo.
Purplebargeken
#83 Post by Purplebargeken »
I had a look at the little right angled hose at the back of the engine and saw that it had perished badly, so that will need ordering. Today was mostly spent cleaning up various manifolds and thermostat housings. The steel piping that various hoses connect to have been taken down to bare metal, rust killed and etch primed. These will then be painted. Taking shape slowly but surely. Can't wait to get it all back together.
Purplebargeken
#84 Post by Purplebargeken »
Haha!! Mick D has sent the bits out. Roll on the arrival!!!!
DazasDolly
#85 Post by DazasDolly »
Purplebargeken wrote:Haha!! Mick D has sent the bits out. Roll on the arrival!!!!
DazasDolly
#86 Post by DazasDolly »
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
Purplebargeken
#87 Post by Purplebargeken »
Well, it has all turned up. I now have more or less everything (apart from a bit of ordinary hose) to sort the Tolly out. Am working on Saturday, so maybe Sunday will see some progress.
Purplebargeken
#88 Post by Purplebargeken »
No progress today sadly but the day was well spent. I helped my friend with the steam engines strip out the flywheel from his Foden 6 tonner. Thanks be for fork lift trucks!
I have also rescued my unused Draper torque wrench from the loft and wonder if anyone could kindly supply me with the correct torque setting for the Tolly head. Nm if possible but not essential.
Ken
NickMorgan
#89 Post by NickMorgan »
Ken,
According to Mr Haynes, cylinder head to block = 38-45 lb ft or 5.2-6.2 kg m. Rocker shaft = 26-32 lb ft or 3.6-4.4 kg m.
Good luck.
Image Thanks Photobucket :(
Purplebargeken
#90 Post by Purplebargeken »
Cheers Nick.
Roll on Saturday!!!!
