There are various proverbs about making haste and repenting at leisure, it’s not quite what I had in mind in describing what has happened over these last couple of weeks since I added my last post. But in taking a short cut, or in my case neglecting to do the obvious, I have had to go back and redo some tasks which I had done earlier. I will describe those tasks in a moment.
I mentioned in my last post that I had changed the rear gearbox seal in order to cure a leak. It did not fix the problem! The leak remained, and it is, or hopefully was, quite a substantial leak. And I only found the cause of the leak because I was trying to sort out my carburettor problem.
I had sent private messages to both Jeroen and Jonners seeking their advice on how I might solve the problem of different float levels in the two carburettors. Jonners made what was an interesting suggestion. Check the rear gearbox mount just in case it has dropped significantly. Jeroen made the point that he did not think that a pronounced sag in that mount would alter the angle at which the engine sits sufficiently to upset the float levels.
But I went ahead and checked the gearbox mount for sometimes it is something which causes a problem elsewhere. And it is very easy enough to do. I put the car up on the open air ramps again and removed the gearbox mount. It was covered in oil but was intact and had or was not allowing the back of the gearbox to drop significantly. Once I had removed that mount though I discovered the source of the gearbox oil leak for when I looked up I could see over the top of the overdrive unit and see where oil was dripping off one of the selector rods. That oil was cascading down over the rear of the overdrive unit and it was that oil which caused me to think that the rear seal had failed.
My only course of action then was to remove the passenger seat, disconnect the handbrake onto one of the rear drums, remove the front carpets and then remove the gearbox cover. Once the cover was removed I then took the top cover off the gearbox, yes the workshop manual says you can do this, without removing the parcel shelf, which was a bit of a plus.
There was a lot of oil visible where the three selector rods come out of that cover. The rods are sealed by three o-rings which are held in place by plate and which is only accessible by removing the selector rods themselves. I had earlier broken the top cover on my gearbox and bought another complete gearbox which I suspect had been sitting outside and left standing on its bell housing. There was evidence that there had been quite a lot of moisture in that donor box. I cleaned the cover of course, and reinstalled the selector rods which were in the cover which I had broken for they were in much better condition than those in the donor box.
But I neglected to do two things.
Firstly I did not fit new o-rings, (I purchased three today for about 35 pence each). But why was the oil coming out past those o-rings? I figured that the gearbox must heat and cool as it is used and there must be some sort of breather somewhere and that perhaps this breather was blocked. If it was blocked then the build-up in pressure within the gearbox was perhaps sufficient to force oil out past any one or all three of these o-rings, which are only held in place very lightly by their cover plate. I found the breather hole right at the front of the top cover, as marked.
- 20130312-4061Ptw HU5000 Gearbox cover.jpg (135.75 KiB) Viewed 3708 times
Of course with the donor gearbox standing on its end this little hole seemed to be blocked for when I blew it out with compressed air there was a little wad of muck released.
The second task is that I should have blown it out when I cleaned the cover originally.
It is easy to be wise after the event. But I hope this will lead others to check, if they have their gearbox apart that this little hole is clear. It sits forward of the end of the reverse selector rod and I imagine that there is sufficient clearance, and fairly minimal movement to allow the internal space within the gearbox to breathe, and which allows air to pass along that selector rod and not allow the oil which might follow, to escape.
I shall report shortly on whether I have fixed the problem when I have replace the gearbox cover, refitted the gearlever, reconnected the handbrake and driven the car. But I can say that when I ran the engine with the car in neutral and the gearlever out before I took the top cover off the gearbox I could see the oil drips forming below the o-ring cover plate. It has not done so since I have put everything back together.
With the cover off from around the gearbox, and with the front carpets removed I shall attend to another little task and that is to remove some spacers from behind the exhaust shield which sits on the firewall/bulkhead. I fabricated my own exhaust shield for mine has been lost in the 24 years since I stripped the car out. I spaced it well off the bulkhead to allow air to circulate behind it but I notice that occasionally the engine rocks sufficiently to allow it to touch.
At this point perhaps I should make a comment about this exhaust shield and how I have discovered that making it possible to unbolt allows me to remove the cylinder head off the engine in the car without any drama at all.
Others have commented in other threads on this Forum about the need to say a prayer or two if it becomes necessary to remove the cylinder head off a Sprint when the engine is still in the car. The problem it seems is the removal of the exhaust downpipe at the back of the exhaust manifold. I have retained the three original studs on my exhaust manifold. When I fabricated a copy of the heat shield which sits on the engine bulkhead I chose instead to bolt it to the bulkhead rather than pop rivet it.
Twice now I have removed the cylinder head with the engine in the car and in both cases the easiest way to remove the exhaust downpipe was to unbolt the heat shield first and remove it and then unbolt the exhaust downpipe.
Unless I am very much mistaken the fitting of all the exhaust heat shields probably came after the prototype cars were developed, and was perhaps not thought necessary in the original design. However after the car had been developed the heat shield in question was fitted to overcome a heat build-up in the passenger side of that bulkhead. It was very easy to pop rivet the heat shield onto the bulkhead during assembly but in doing so those who formulated the instruction to rivet the heat shields in place forgot that this technique possibly made it very difficult to remove the exhaust downpipe at some later stage.
I rather imagine that it would have never been a problem in the factory for if like the car which I have been rebuilding there was a problem with the engine or its transmission at the end of the assembly line the whole car assembly was probably moved into some form of remediation area where the complete sub-frame assembly was removed and a spare fully assembled engine sub-frame assembly substituted. It would have taken no longer than 90 minutes to make the change and this process would have helped the production team to achieve the targets set of so many cars coming off the line in any nominated period.
Faulty engines, gearboxes or clutches would have possibly been put right in this remediation area and would have been held waiting for the next sub frame change if and when it was needed. There would have been no need to remove exhaust downpipes using this technique, so there would have been no need to remove the heat shield and the problem would not have been noted by the designers.
I am learning as I go along. The spacing of that heat shield is tight for there is not much room and I could only guess how far to space it off the bulkhead when I installed it originally. And I am learning that not installing new o-rings which have minimal value was false economy too. Just as neglecting to blow out that small breather hole on the top of the gearbox has caused me to go back and redo the job properly this time.
I suspect that at some stage, if my returning of this car to the road continues in the way it has then perhaps I too will be able to claim like Jonners that “If I haven't done it in or to a dolomite....”! I hope not for I want to use the car now and wear it out before it wears me out.
Nobody so far has been able to answer my query on whether I should fit grommets to the holes in the underside of the car, one of which I marked in my previous posting. And nobody either has commented either on the lack of detail in the wiring diagram.
How does the headlamp flasher switch connect to or where does it connect to the high beam circuit?
Finally on a much more positive note. I spotted 2drToledo/Jim’s offer of a Stainless Steel and Chrome O/S door mirror which he is offering for sale. Jim was very prompt in answering my queries and obtaining a quote to post it to New Zealand. Mad Mart has also given me the name of a possible mirror supplier. In the meantime though I have unearthed a couple of black painted mirrors which were sold in the early 1980’s and my thinking now is to fit one of those on the off side door of my car. So I thank Jim here for the effort he went to on my behalf and hope that his mirror will find a good home elsewhere.
