KLJ895W tinkering...
lazeruspete
Re: KLJ895W tinkering...
#151 Post by lazeruspete »
They're the ones that came with the cage and they're 140cm^2 in area :-)
viewtopic.php?f=19&t=23031
Proud TDC Member!
#152 Post by Jon Tilson »
If you feel like going into production on that cardboard templated area I'll join the queue of customers.
lazeruspete
#153 Post by lazeruspete »
How much would you pay and how much more of it would you like Jonners? :-P
Proud TDC Member!
Oli_88
#154 Post by Oli_88 »
Aye, if an accurate and cost effective patch panel can be made, that'd save dozens of cars on its own... For those unwilling to buy the excellent GRP ones available from Alun anyway.
Hit it.
lazeruspete
#155 Post by lazeruspete »
Oli_88 wrote:Aye, if an accurate and cost effective patch panel can be made, that'd save dozens of cars on its own... For those unwilling to buy the excellent GRP ones available from Alun anyway.
Hmmmm intriguing......
Proud TDC Member!
lazeruspete
#156 Post by lazeruspete »
How much interest in eyebrows do you think there would be?
Proud TDC Member!
Nick C
#157 Post by Nick C »
lazeruspete wrote:They're the ones that came with the cage and they're 140cm^2 in area :-)
Fair enough, hard to tell sizes from photos...
lazeruspete
#158 Post by lazeruspete »
good evening ladies and gents.
more progress to report on!
this is what we started with
cut the flange off
make a new one
and weld it on
oh look, a hole
promptly filled in
another hole, you can see where the previous patch has been ground down flush
tadaaaaaaaaaaaa
more weld
as new :D
Proud TDC Member!
SandglowISnice!
#159 Post by SandglowISnice! »
Some fine work on the feet - that reminds me...must get new Arc welder out of box.. and use!
Smartt progress again Pete, I'd say you've done about 2 years average work on a Sprint in say...3 months? :wink:
lazeruspete
#160 Post by lazeruspete »
SandglowISnice! wrote:Some fine work on the feet - that reminds me...must get new Arc welder out of box.. and use!
Haha it feels like it too! :-P
Proud TDC Member!
#161 Post by Jon Tilson »
Given that few if any of us would have the skill to do that, the repair section would need to go slightly bigger that the bits you cut out and have the flange right down to the lights....so a pretty complex curved old piece then....
Has to be worth 50 quid a side though....
lazeruspete
#162 Post by lazeruspete »
Jon Tilson wrote:Given that few if any of us would have the skill to do that, the repair section would need to go slightly bigger that the bits you cut out and have the flange right down to the lights....so a pretty complex curved old piece then....
hmmm intruiging. i'll talk to alan about it.
progress report imminent by the way....
Proud TDC Member!
MalcGE
#163 Post by MalcGE »
I wish I could weld like that. I put a partial wheel arch repair on my transit van last year, but my welding is not very neat and there was a lot of liaising of weld to be done and a tad more P38 than I would have liked.
Your man is welcome to come and do the offside arch and lower rear doors of my van if he is short of soemthing tomthrownthe mig at, craftsmanship is what he has done, hats off to the chap
lazeruspete
#164 Post by lazeruspete »
MalcGE wrote:I wish I could weld like that. I put a partial wheel arch repair on my transit van last year, but my welding is not very neat and there was a lot of liaising of weld to be done and a tad more P38 than I would have liked.
im sure he will be flattered!
Proud TDC Member!
lazeruspete
#165 Post by lazeruspete »
work on the sprint has been rather slow the last couple of days.
learning that the N/S wing is 10mm longer than N/S set us back a bit so a rework of certain things was required! its a long and arduous tale.
sans flange
with flange
oh look, a hole
not anymore!
mmmm grinding
another hole. at this point we removed the eyebrow so we could prepare that for welding
such as zinc primer and punching for spotwelds
build the eyebrow back in and then give it its water trap roof back. triumph really couldnt have designed a better water collector!. i would upload a picture of the eyebrow welded in but it isnt that interesting :P
and finally weld it all together!
with any luck and a tail wind i will have a complete front end picture for you all tomorrow :D
exciting stuff :)
Proud TDC Member!
