Sprint Spot Lights
kevin
Sprint Spot Lights
#1 Post by kevin »
Sorry to trouble you, I am about to purchase a Sprint , its what i've always wanted and something for me for a change.....
I wanted to put Spot lights on it . Its 1976 . I want to keep the car as original as possible. Does anyone know what is the best for the car re keeping it authentic ? Would this be Lucas ? Does anyone know where I would get these from and the white or black covers that I have seen on a few Dolomites.
Like this I guess..........
http://i2.photobucket.com/albums/y37/Wo ... C01251.jpg
really appreciate this . I will Joint the club at the weekend .
Kevin
kevin@webdirections.co.uk
Re: Sprint Spot Lights
#2 Post by Jon Tilson »
Look for lucas spots one ebay woul;d be my advice as well as placing a wanted add on this forum.
Whatever you get please use proper relays. The column dip switch is marginal for the existing lights as it is, so extra load of spots will burn out
the main beam contacts pdq.
covcourier
#3 Post by covcourier »
One of my old cars. Spotlights had been removed by the time I got it along with that steering wheel and the wheels. Not sure how old them pinctures are but it wasn't as good as it looked. Went to somebody in Denmark. I still have the number plate on retention.
#4 Post by MIG Wielder »
Hi Kevin, Welcome to the board. How about this as an alternative suggestion. On my 1850 daily driver I have standard outer headlamps and 75W halogen inners for the main beam. You can spot a rabbit at 500 yards. So spot-lamps ? Not necessary in my opinion, and they restrict cooling into the rad;
HTH,
kevin
#5 Post by kevin »
Hi Tony , yes maybe that's best . Less Hassle,,,,,,, big ta - kevin
mach1rob
#6 Post by mach1rob »
I know they're not to everyones taste, but I don't care, I like them and that's what counts.
to compare, my PI had period Lucas spots, but these seem to go for silly money unless you're lucky.
kevin
#7 Post by kevin »
yeah I like both to be honest I will end this topic by posting a photo .
cheers kev
S3George
#8 Post by S3George »
Picture of mine at the start of the RSAC 3 Lochs Classic run, brackets designed to be hidden behind the bumper with the lamps removed
Sprint with cibies.jpg (311.06 KiB) Viewed 1884 times
S3George
#9 Post by S3George »
Picture with lamps removed
Sprint without cibies.jpg (276.97 KiB) Viewed 1883 times
stranter
#10 Post by stranter »
Has the Landie been washed with water that's too hot? :D
S3George
#11 Post by S3George »
The wee Landie is my other hobby, it's a toylander, just sneaked into the picture
