Sprint Headers
lazeruspete
Re: Sprint Headers
#16 Post by lazeruspete »
i'm guessing they don't show any dolomite ones because they won't have made many. i saw a Tony Law example on Ken Osbourne's black racecar sprint earlier this year.
and I only mentioned JP as he has made Vauxhall XE manifolds recently so am considering him to make mine! :P
viewtopic.php?f=19&t=23031
Proud TDC Member!
Dolly-Nut
Re: Sprint Headers
#17 Post by Dolly-Nut »
I too have seen that car, artwork.
lazeruspete
Re: Sprint Headers
#18 Post by lazeruspete »
sadly in the race he had a similiar issue to what we have recently been discussing, trailing arm/axle failure! (i don't know which exactly. me/my dad have been meaning to call him)
ended up with retirement as there wasn't much rear tyre left.....
Proud TDC Member!
Hobo
Re: Sprint Headers
#19 Post by Hobo »
Tony Law exhuasts are not a straight forward fit.
The car needs to go to them to have the System fitted.
You will also require the Turret to be cut out in order for the system to clear, these systems are for track / race cars unless you want to go chopping out chunks out of your nice road car :wink:
lazeruspete
Re: Sprint Headers
#20 Post by lazeruspete »
Hobo wrote:Tony Law exhuasts are not a straight forward fit.
quite correct!
the lack of clearance on a sprint engine is ridiculous!
Proud TDC Member!
Hobo
Re: Sprint Headers
#21 Post by Hobo »
quite correct!
Yep, esp when you look at a TR7, in it falls!
Re: Sprint Headers
#22 Post by Carledo »
quite correct!
Yet another reason to not use a Sprint engine if you want a properly quick Sprint! (Dives for cover!!!!)
lazeruspete
Re: Sprint Headers
#23 Post by lazeruspete »
quite correct!
I need about 3 pairs of hands to count all of the reasons on ;)
Proud TDC Member!
Re: Sprint Headers
#24 Post by soe8m »
BANG. :spar: :allbetter:
grelley
Re: Sprint Headers
#25 Post by grelley »
A number of years ago when I was racing my Sprint I bought a F3 motor from Holbay. It had the oil filter housing machined off the block as it was dry sumped and had a remote filter. This allowed me to fit a small Japanese starter motor where the housing had been. Doing this meant I could remove the massive Lucas starter which gave me a lot more room to build and fit a tubular exhaust header. It would also be possible to stand the motor up a little giving a bit more clearance. The works engines still managed in excess of 210 hp with the cast manifold so it cant be that bad.
Grelley
grelley
Re: Sprint Headers
#26 Post by grelley »
Found a couple of pictures of what I am talking about
RichardHyde
Re: Sprint Headers
#27 Post by RichardHyde »
Happy xmas all !
Found this place which makes tubular exhaust manifolds for £428 ... Retro-engineering.co.uk
Cheers, Richard
DF
Re: Sprint Headers
#28 Post by DF »
No point in doing a tube header for a sprint
Unless your going well over 7k and want 220 hp +
A standard manifold well fettled will be ok for 99% of what people
Want out of a road and track day car
You would gain more just removing some weight from the car,
lazeruspete
Re: Sprint Headers
#29 Post by lazeruspete »
i thought i recognised that website...
viewtopic.php?f=3&t=20386
seems like they don't have a great reputation (going on what happened to this french gentleman)
Proud TDC Member!
wiggybum
Re: Sprint Headers
#30 Post by wiggybum »
DF wrote:No point in doing a tube header for a sprint
Is there any advice out there on how best to port the cast iron Sprint manifold? Aside from matching the ports,there's not much material to grind away - or at least I can't see where you'd try.
1981 1500 HL man/od
2007 MX5 Sport
2010 Citroen C1
1993 Gas Gas GT32
