new dizzy
wheels
new dizzy
#1 Post by wheels »
http://www.aseriesspares.co.uk/ignition ... t_113.html
Hi
I need a new dizzy for my Sprint, just wondered if anyone had purchased one from the above ?? They do a fast road version at a reasonable price compared to a standard rimmer bros re-con.
Any information greatly received
John
cliftyhanger
Re: new dizzy
#2 Post by cliftyhanger »
If you are looking at the one that fits sprint/herald/spitfire they have got it wrong. Sprint dizzy different animal to the OHV engines.
Re: new dizzy
#3 Post by Toledo Man »
The Sprint uses a Lucas 44D4 dizzy. They use the same points and condenser as the 45D4 but that's where the resemblance ends.
wheels
Re: new dizzy
#4 Post by wheels »
Thanks for the information it might have to be a rimmers job
cheers
cliftyhanger
Re: new dizzy
#5 Post by cliftyhanger »
try h+_h ignitions, they are specialists with a good reputation. I suspect rimmers just put the work out to whoever is cheapest?
AlanH
Re: new dizzy
#6 Post by AlanH »
If your looking for programmable ignition this looks interesting.
http://www.ebay.co.uk/itm/Electronic-ig ... 2a2bf3c161
cliftyhanger
Re: new dizzy
#7 Post by cliftyhanger »
But no vac advance......
If doing that a megajolt or nodiz would be a better option (with a bit more faff/expense)
Re: new dizzy
#8 Post by Toledo Man »
Alan, according to the listing, it isn't compatible with the Sprint. The seller is one I'd recommend though. Others to try are the Distributor Doctor or SimonBBC. An electronic ignition kit such as the Lumenition would be the best way to go and they're not affceted by timing scatter caused by a worn dizzy shaft. I'd recommend the Britpart kit but I don't know if it would fit under the Sprint rotor arm.
Okay.....
#9 Post by sprint95m »
wheels wrote:http://www.aseriesspares.co.uk/ignition ... t_113.html
Hi
John
If you are going to spend that kind of money John, I suggest you also consider a 123 distributor.
The one for a Spitfire 1500 can fit a Sprint, you need to fit a side entry cap and change the drive gear for the Sprint one (needs an adapter
that any machine shop will make easily). A Dolomite 1500 distributor clamp can be adapted to suit.
Re: new dizzy
#10 Post by Mad Mart »
I just tried various Dolly models and it doesn't seem to fit any of them!
Neil907
Re: new dizzy
#11 Post by Neil907 »
I have the stealth module on my Jensen. The chip for talking to the laptop is useless and doesn't always work, but once you have convinced it to connect it all seems to work pretty well and give good control, though it has its limitations. Also bought a complete distributer from them and am less impressed with that, it was cheap and it shows.
The reason I went this route rather than megajolt was to keep it looking original which in reality is a pretty stupid reason.
Re: new dizzy
#12 Post by Mad Mart »
Neil907 wrote:The reason I went this route rather than megajolt was to keep it looking original which in reality is a pretty stupid reason.
:lol:
AlanH
Re: new dizzy
#13 Post by AlanH »
Different Ebay entries give different cars (including Aston Martin !).
It's external, fully programmable and it says at the bottom that it can be used with any distributor that has electronic points.
Having said that, if a 123 can be made to fit I think I would go for it.
Re: new dizzy
#14 Post by soe8m »
123
dursley92
Re: new dizzy
#15 Post by dursley92 »
Jeroen, looks perfect but which 123 distributor is that please? When I asked them recently about one for the Sprint they said they didn't do one. I need it to go under a Weber type inlet manifold.
Russ Cooper
Dursley
UK
