HELP - Dolomite Sprint engine mounts
Hi All,
Please can someone tell me which way around the metal brackets fit on the cylinder block , as they are handed
And also which way the rubbers go on , as the studs are off set
Many thanks Simon
Many thanks Simon
Re: HELP - Dolomite Sprint engine mounts
The deeper one goes on the nearside and the cutouts go at the top.
I think the rubber blocks should be symmetrical when new and the studs are in the middle of the mounting plate.
Hi John,
Thanks for the info , do you have any pics please
Also of the rubbers , as the studs are off set from the bolt holes that fit onto subframe
Thanks Simon
Thanks Simon
As Jonners said. The cutouts to the top & front. The rubbers are symetrical so will fit on either side.
Thanks for the diagram
Still confused about the rubbers
They are both the same , not handed
But the studs that go through the metal brackets are higher on the rubbers , or lower on the rubbers
Will send a pic
Thanks Simon
Will send a pic
Thanks Simon
Here are some pics
- image.jpg (261.49 KiB) Viewed 1254 times
Or this way around ??
- image.jpg (288.21 KiB) Viewed 1254 times
I have found the same, there is a 1/4 inch or 6.35mm off-set between the two holes and the studs.
To level out my engine and gearbox I have one up and one down but presently seem unable to get the last two bolts in.
Malcolm
Malcolm
Are these new old stock or "repro"
As Mart said, they should be symetrical.
Probably why you are having grief fitting them.
Jon
Jon
Hmmm!
I'll check out the mounts I have tomorrow (erm, today). If they are offset then I would mount them as the bottom pic with the studs offset to the top.
I've checked and, as I thought, the studs are in-line with the holes.
Many thanks for your help
Sounds like you are both suffering from repro rubbish then.
Its hard enough fitting the near side one when they are right if you are unlucky, Sometimes they do just plop right in.
If its out of alignment like this you are on a hiding to nothing. I'd send them back if recently purchased.
I have a suspicion TR7 ones are the same, (rubber bit) but use different brackets.
