Rusty sills
colinwoods
Rusty sills
#1 Post by colinwoods »
Hi all,
I'm looking to have my sills replaced as they are very rusty. So rusty I fact they you can fit four fingers in some of the holes... Both sides need doing.
I've been given a ball park worst case scenario quote of £1,600. I'm a little concerned at the car only cost me £1900 and I've spend more than that on it over he past two years. This said, runners have the three layers available for around £300 each side. Is circa £1000 good for labour?
What's your thoughts re costs for this, and will I need to have a respray afterwards?
Thanks for your help.
dailysprinter
Re: Rusty sills
#2 Post by dailysprinter »
It sounds dear to me, then I would just cut out the rusty and graft in sections with the welder. If you have good original sills, not too bad this can be a better solution that cutting the whole sill off and replacing.
It is difficult to say what cost could be, as it may include innner outer sill and jacking points. Try posting some pics so we can have a look.
As regards to a respray that will depend on the finish you want, they can be painted black and no actual respray.
1979 Triumph Dolomite Sprint Highly Modified
2006 Triumph Sprint St 1050
2012 BMW 318d Touring
Re: Rusty sills
#3 Post by Carledo »
I'm sure the club sills are cheaper than that and £1000 labour is exorbitant!
Re: Rusty sills
#4 Post by xvivalve »
You can have all three cill sections delivered, both sides for £255. That is if you need all three sections both sides?
Unlike other cill sections, the club panels are zintec and the reinforcer is a faithful reproduction of original equipment.
Make contact with a local member who can advise what you actually need.
Cost for fitting depends on how much needs doing...
Re: Rusty sills
#5 Post by Jon Tilson »
I can point you to a man who would happily fit Alun's club cills to your car for a lot less..
In chalfont st giles so not tooooo far from East London...about 30-40 miles round M25
PM me if interested and I'll put you in touch...
