hi my names phil and ive just joined this site. my project is putting an mx5 1.6 engine and gearbox and ive noticed that other people are doing the same thing on here. reading through the threads i found them having the same problems that i had. ive nearly completed the conversion now so if anyone would like any tips or advice im happy to help. i will aslo try and upload photos aswell, ive got a few of them! working on the dolly over the weekend so will take up to date pics.
- this is just the mock up of the engine bay. pic just to give you an idea of how it looks.
- 11083895_890184834354192_340473448994666895_n.jpg (69.71 KiB) Viewed 440157 times
Nice to see that the servo and master cylinder still fit, more pics plz
Welcome to the forum.
Please keep us updated with your progress.
I will upload more tomorrow as I'm spending the day in the workshop. Under the bonnet is about 90% there now so you can see how much room is left or the lack of it!
managed to work on the car for 7 hrs today so got some more done to it. took a load of pics today whilst i was getting stuff done. more pics on next post.
- handbrake lever with spacers under front will clear gear linkage, just need to mske new angled mounting plate
- 11905806_963677443671597_8549904296733892808_n.jpg (45.25 KiB) Viewed 440096 times
- battery tray before paint applied
- 11904094_963677200338288_2661467909837148951_n.jpg (54.34 KiB) Viewed 440096 times
- passenger side engine mount and modified sump
- 11941242_963677023671639_2046650445487528197_n.jpg (39.97 KiB) Viewed 440096 times
- battery fitted in car
- 11903752_963677297004945_4399093695673663136_n.jpg (64.33 KiB) Viewed 440096 times
- fabricated battery box and fitted
- 11947566_963677273671614_515253698169150900_n.jpg (56.73 KiB) Viewed 440096 times
- room round cluth slave cylinder
- 11949448_963677107004964_2901008523460421053_n.jpg (58.22 KiB) Viewed 440096 times
- one of the fuel lines
- 11951203_963677180338290_4587571892755669253_n.jpg (64.66 KiB) Viewed 440096 times
- dismantled gearstick
- 11952032_963677343671607_2409729841939233048_n.jpg (68.34 KiB) Viewed 440096 times
- drivers side engine mount
- 11954670_963676997004975_1650589504577471795_n.jpg (54.26 KiB) Viewed 440096 times
- view of the modified mazda electrics
- 11954674_963676887004986_8443972847526005086_n.jpg (74.06 KiB) Viewed 440096 times
more pics of car.
- air filter bracket, bottom radiator hose braket and you can just see the dip stick
- 11870649_963677223671619_7627279724751845372_n.jpg (29.01 KiB) Viewed 440096 times
- air intake side of engine
- 11892066_963676930338315_3384120771980631970_n.jpg (66.84 KiB) Viewed 440096 times
- attempt 2 and its nearly in the same place as old one. need to make a better looking one now i know it works
- 11892075_963677423671599_183348621229955815_n.jpg (62.32 KiB) Viewed 440096 times
- first attempt works but stick position isnt right
- 11873791_963677397004935_4288927548112020404_n.jpg (45.1 KiB) Viewed 440096 times
- gearstick stub fitted to take measurements
- 11222192_963677377004937_1711190152136393728_n.jpg (49.39 KiB) Viewed 440096 times
- gearstick position needs moving foward more
- 10308218_963677317004943_5735362964435097598_n.jpg (70.89 KiB) Viewed 440096 times
- dolomite exhaust modified to meet mazda down pipe
- 11896069_963677153671626_4892322049169363305_n.jpg (51.96 KiB) Viewed 440096 times
- gearbox mount
- 11898634_963677080338300_3105351315744420268_n.jpg (60.51 KiB) Viewed 440096 times
- radiator clearence
- 11902420_963676960338312_6996587291836219236_n.jpg (56.05 KiB) Viewed 440096 times
- gearstick with rubber shock absorber removed ready for modification
- 11903747_963677360338272_6993075934209553540_n.jpg (66.61 KiB) Viewed 440096 times
a few more pics.only let me put 10 on at a time so took a while. thats my progress so far, just need to finish of the gearbox tunnel area, some wiring, fuel pipe inside the boot, thermo control switch for fan. speedo cable and try to link the rev counter into the mazda electrics. just lots of little fiddly bits that take ages and dont look like youve done anything.
- drivers side of engine.
- 16923_963676907004984_5376901530638904976_n.jpg (74.53 KiB) Viewed 440095 times
- underside of car
- 11140292_963677063671635_1157846318902063003_n.jpg (45.36 KiB) Viewed 440095 times
- fuel return going over gearbox and exhaust
- 11215160_963677127004962_8526423638372714840_n.jpg (66.96 KiB) Viewed 440095 times
- stopped to have some food so took pic of car on ramp
- 11231856_963677253671616_1114691158017697233_n.jpg (51.26 KiB) Viewed 440095 times
- front view of underside
- 11863265_963677047004970_8407247528958996849_n.jpg (49.39 KiB) Viewed 440095 times
Looking good keep at it, have you done the shortening mod which moves the whole selector about 6" further forward
http://the-mite.com/mite18.htm can't do the linky thing on this silly windows 10, you'll have to cut and paste it in your browser
Some good work there, I like the remote gearstick idea
. Can you get a push fan in front of the rad- it looks tight for a pull fan?. Where did yuo get the sump from? Is that another elusive 323 turbo one? What are you doing for fuel pump- in tank or bosch style external?
I shortened the selector shaft before I even New about the link on how to do it but I did it the same way. I'm an agricultural engineer so I'm used to taking things apart. I've fitted a 12 inch push fan to the front as there's plenty of room there and just need to wire it in. It didn't take long to think up the gearstick thing it was just trial and error. The way I've done it the plastic trim should go back on once I've 're built the gearbox tunnel.
Forgot to mention I got the sump off eBay for under £60 for a new one.
i fiited the mazdain tank fuel pump i just removed the gauge sender unit and had to adjust the angle of the pump slightly. the sump is marked up and ready to cut, while the front of the sump was missing i altered the oil pick up tube. it made it easier as you can see where it sits in the sump. the sump hasnt got gearbox bolt holes on it but you can make brackets that pick up on the threaded holes on the side of the block, me and my colleague dont think yhat it will need them though as hes put a rover v8 in his tr7 and thats only got 4 bolts holding the gearbox on and they are a smaller thread size aswell.
- sump
- 10984138_893766493996026_3576509195927569526_n.jpg (112.78 KiB) Viewed 440049 times
- fuel tank mod
- 11896080_963943633644978_5190412392094395051_n.jpg (60.76 KiB) Viewed 440049 times
Going to spend a few more hours in the workshop tomorrow. My plan is to get fuel lines completely finished off and put wiring in for the fuel pump so that I can get it running.
just a quick update while i have some lunch. today i have finished off the fuel system. fitted fuel filter after fabricating a bracket. will put pics up later. also i have wired in the fuel pump. engine fired up straight away but had no ingnition lights, voltage gauge or temp gauge. temp guage was an easy fix just had to connect the dolomite wiring to the mazda temp sensor. ignition lights envolved cutting into the dolomite altinator wiring and connecting the ignition live up the the mazda altinator, once that was done i had dash lights and voltage gauge was working. also battery is charging at 14v. next step is to repair a broken wire on one of the ecu plugs on the engine.
Congrats on getting it running. Your experiences will help the others who are doing the MX5 conversion.
