D-post exterior fabric
Re: D-post exterior fabric
There are two type of evo-stik (actually there are lots, let's not go there), the 'normal' old fashioned type and a type that won't melt the plastic.................it tells you on the tin.Mahesh wrote:Plastic or vinyl, mine are most likely rusted, I will have to remove to be sure.
I was going to use polyurethane type evo stick, but after reading the post, could
do with some guidance.
I love the smell of the old stuff..........
Here's hoping there's no dreaded underneath...but no doubt knowing my Donald Duck!!!Edin Dundee wrote:Yes, afraid so. Sometimes the crinkling when pushed is just the plastic.
Hi Bill, when I spoke the chap at LBH he didn't specify whether the D Post material was plastic or the same material as the vinyl roof. I really only require one side but may replace them both so they match.
David
David
Hello Dave.
I too had a small area of grot under my trim on the offside. I managed to peel back the original plastic enough to clean up the small area of rust, however I was never happy with the plastic afterwards.
I picked up some vinyl from either the NEC or Resto show and they also supplied some adhesive in a tin to apply by brush. This I applied to the body of the car before applying the vinyl covering. I left it overnight before trimming the excess and fitting the trim back on etc.
If you get a decent length of material, you can have a couple of goes at it!
Matt Cotton
1980 1500HL - OPD
1976 Sprint - SWU
1980 1500HL - OPD
1976 Sprint - SWU
That sounds like a good course of action Matt
does anyone have pics of their finished replacements? I'm wondering if vinyl would be better than the plastic? It would surely be easier to come by I'd imagine?
Kind Regards
Russell
Kind Regards
Russell
Hi all,some interesting comments on this subject,it seem's like the vinyl is the way to go,the type of adhesive being important also,
thanks everyone,Myles.
Martrim make the panels from vinyl, similar to the roof material. I know they have seams in them where the 90 deg. angle is but I've not actually seen any in the flesh.
Hi Everyone
An interesting discussion. I'm going to need a little more research. I'm really wondering if the grot may not be so bad as it sounds but as has been said, I won't know until I take it all off and look.
Thanks for the comments and will keep all posted.
