How bad is my Sprint?
shaunroche
Re: How bad is my Sprint?
#241 Post by shaunroche »
Will be coming back to this wiring malarkey as having got the MGB type fuse box I'm about as confused as a baby racoon!
Still, got the refurbed Sierra brake calipers on Trackerjack 's brkts which are looking a bit mint! They also fit under std wheels and will be getting the aeroquip type hoses on soon, front and back....
As I've shown in another thread, the brake plumbing is under way despite everything being imperial and the two fittings in the tandem master cylinder being metric!
Next jobs are to sort all the extra wiring routes etc. and to create the cradle for the fuel tank hoping that all the braised hose fuel fittings will be waiting for me when I get home tonight...
#242 Post by MIG Wielder »
shaunroche wrote:Will be coming back to this wiring malarkey as having got the MGB type fuse box I'm about as confused as a baby racoon!
Next jobs are to sort all the extra wiring routes etc. ...
Hi Shaun, Here is my installation of the MGB 4-fuse box. Ignore the external mega-fuse for the headlights btw.
mod fuse box ext.jpg (89.77 KiB) Viewed 1883 times
mod fuse box int.jpg (89.95 KiB) Viewed 1883 times
HTH,
shaunroche
#243 Post by shaunroche »
Cheers Tony. only just spotted this....will have a go at it this weekend!
shaunroche
#244 Post by shaunroche »
Got a little more done this evening...trial fit of the fuel tank and cradle.......
shaunroche
#245 Post by shaunroche »
....fuel tank and cradle fab'd up by Super Al.
Holes drilled and rubber added to the feet, just need to paint the holes in the chassis I drilled and we're away....
shaunroche
#246 Post by shaunroche »
Still battling with the baffling electrics but think I'll get it sorted sooner or later - in the meantime I've wired the rear of the car up and got a feed and earth to the fuel pump.
Have got the fuel tank sat in its bespoke cradle and fastened to the boot floor and have got the fuel lines plumbed in now though I am worried to death about them leaking, despite them screwed up pretty tightly......
Almost got the brakes plumed up, just waiting for Super Al to come round and plumb the braided hoses to the front and back.
Slow progress....not quite the latest pic as I've tidied all the wiring up , but it's progressing...
Additionally the Master cylinder literally popped to bits the other night with no external influence...there was a clang and I searched around in the foot well and the clevis pin/rod had just fallen out!
Got a refurb kit from Rimmer's and sorted it all tonight. Thanks to James for his clear and easy to understand pics etc...
A tad on the properly filthy side.....
Anyhoo, after disassembling, cleaning, fitting new seals and adding the grease etc., I appear to have a bit of the kit left over!
What's the big rubber washer for, anyone? It doesn't appear in the parts manual....
#247 Post by Carledo »
You don't need that big rubber ring, it's to go inside the reservoir cap on models with the reservoir on the cylinder.
shaunroche
#248 Post by shaunroche »
Carledo wrote:You don't need that big rubber ring, it's to go inside the reservoir cap on models with the reservoir on the cylinder.
Ha, course it is!....I recognise it now you've pointed it out Steve! :)
James467
TDC Sprint Registrar
#249 Post by James467 »
No problem sir, glad to be of assistance! \:D/
iandollysprint
#250 Post by iandollysprint »
Just seen your avos on the front. Watch the bottom bush when you get it on then road, they are absolute rubbish - destroyed mine in 2000 miles....they are a known problem. Ian
shaunroche
#251 Post by shaunroche »
Just seen this Ian....the bottom bushes in the damper you mean? Can you repack them?
iandollysprint
#252 Post by iandollysprint »
Yes bottom bush on the damper. They fail and the destroy the eylet.. Not good.
Ian
#253 Post by soe8m »
Had these made a while ago with a uniball. Wasn't much extra costs. Sorry for the poor pic.
shaunroche
#254 Post by shaunroche »
No worries Juri - thanks for posting.
Juri/Ian can these ball joint things be retro fitted?
I'm assuming I don't need to send them back or worse still, replace the entire unit?
shaunroche
#255 Post by shaunroche »
Details to follow, but have wired up the relay and fuse board today.....
Image fallen off..
