I have a few Sprint cylinder heads
What are the visual differences between the two ?
I know late heads have a number "2" stamped on them
Many thanks
Simon
Early v Late SPRINT cylinder heads - differences ??
- trackerjack
Re: Early v Late SPRINT cylinder heads - differences ??
Very early ones had shallower spring seats, which when used with uprated camshafts wrecked the head due to spring coilbound problems.
I also think the waterways were enlarged but I am not sure.
See Mikes restoration thread viewtopic.php?f=19&t=7537
Steve and Nic
Larger garage needed
I have put both heads side by side
The only difference visually is the extra casting above the exhaust ports on the later ( number 2 casting number )
Simon
Simon
- image.jpeg (250.17 KiB) Viewed 1189 times
- image.jpeg (291.03 KiB) Viewed 1189 times
- image.jpeg (288.73 KiB) Viewed 1189 times
Have a look at my thread about early vs late heads, I think there's a link to Mikes thread as well.
viewtopic.php?f=19&t=27969&start=345
I have had a problems with the spring seats on my early one being too high, they really need to be machined down but as I now have a late one I'm just going to use that.
