Gauges and clocks are a secondary job which in the scheme of things get done first, but back
to the water leak,
Loose bolt noticed (probably the stereo loosening up everything)
- 20160519_074918_1463644324258.jpg (218.05 KiB) Viewed 1179 times
All three (speedo, heater, choke) cable grommets are letting in some water,
- 20160519_075017_1463644324422.jpg (295.3 KiB) Viewed 1179 times
There was a hole in the top at the wipers which probably done this,
- 20160519_075110_1463644324543.jpg (231.65 KiB) Viewed 1179 times
Not sure much can be done at the moment, other than a bit of jenolite and hammerite.
More water is coming in from the tunnell back area, (pic to follow) theres a big hole there)
and also from somewhere else, (qed).
