Setting the tracking
- IMG_20160806_210153.jpg (184.52 KiB) Viewed 17835 times
- IMG_20160806_210229.jpg (173.76 KiB) Viewed 17835 times
Today I repaired the rust hole on the passenger side a piller. First I cut the top rear section of the wing off to gain access to all of the rust. I then removed the paint and found more holes. I then cut out the rotten metal and cleaned up around the hole. Fabricated new over size section then spent ages cutting and grinding to make it fit and welded in. Applied some filler and sanded down then painted with primer then black as that's all I had. I then welded the part of the wing back on and ground the welds down then filled and painted.
- Before I started
- IMG_20160807_214829.jpg (157 KiB) Viewed 17817 times
- Section of wing removed
- IMG_20160807_214931.jpg (173.39 KiB) Viewed 17817 times
- Paint removed
- IMG_20160807_215030.jpg (169.03 KiB) Viewed 17817 times
- All rotten metal cut out
- IMG_20160807_215124.jpg (189.48 KiB) Viewed 17817 times
- Cut out section
- IMG_20160807_215221.jpg (174.89 KiB) Viewed 17817 times
- New panel fabricated
- IMG_20160807_215327.jpg (192.57 KiB) Viewed 17817 times
- After a lot of cutting and grinding panel fits
- IMG_20160807_215404.jpg (174.89 KiB) Viewed 17817 times
- Tacked in place
- IMG_20160807_215449.jpg (163.5 KiB) Viewed 17817 times
- Welded and ground smooth
- IMG_20160807_215537.jpg (174.28 KiB) Viewed 17817 times
- Filled and painted
- IMG_20160807_215620.jpg (186.21 KiB) Viewed 17817 times
Last couple of pics. Still needs finishing but it will keep the rain out now.
- Wing section welded back in
- IMG_20160807_215709.jpg (187.34 KiB) Viewed 17817 times
- IMG_20160807_215801.jpg (174.58 KiB) Viewed 17817 times
Great metalwork skills!
Very jealous of that repair section you made. I've been pondering making that same section for the past few weeks but I've yet to pluck up the courage.
I have a good scuttle/screen frame section from a scrap car if you want to short circuit the process a bit! I will be in Somerset in 3 weeks or so and probably at TDCIR for collection if that helps.geeksteve wrote:Very jealous of that repair section you made. I've been pondering making that same section for the past few weeks but I've yet to pluck up the courage.
It's 2 pieces welded from the inside so there was enough thickness to round the edge over to match the existing panel shape. The whole job took 6 hours and it still needs more blending in. The next repair I'm thinking about doing is the rear arches. Might buy the panels for that. Bit more of a tricky shape to make! Cutting big holes in your own car always takes courage. Just want to say sorry for causing it pain.lol. the good thing is it doesn't whistle whilst going along now.geeksteve wrote:Very jealous of that repair section you made. I've been pondering making that same section for the past few weeks but I've yet to pluck up the courage.
Today on the way home from work I was driving along. Put my foot on the clutch pedal to change gear and there was a twang noise from the pedal, lifted my foot up and I have a floppy pedal. The pedal return spring gave up so now I need to keep my foot under the pedal to hold it up. Guess what Im going to be repairing tomorrow in my lunch brake!
Today I decided to re fit the lowered springs to try and improve the handling. When I did the fronts I found that passenger side standard spring was shorter than the driver side. Thought it was handling a bit odd. I also found that 3 out of 4 shocks are on the way out. To do the rear shocks I had to remove the battery tray so while it was off I decided to put the boot lining under it to tidy it up a bit. Then I dug out the front spoiler and fitted that. Suspension properly seteled after a little drive to a well known fast food restaurant. It handles so much better now and doesn't wobble around corners, can go into them with a bit more confidence now.
- Before I started
- IMG_20160813_224540.jpg (203.34 KiB) Viewed 17734 times
- Removing first spring. Didn't see the point in taking pics of every one.
- IMG_20160813_224618.jpg (181.3 KiB) Viewed 17734 times
- Standard and lowered front spring
- IMG_20160813_224654.jpg (170.72 KiB) Viewed 17734 times
- Hight difference between removed front springs
- IMG_20160813_224738.jpg (167.44 KiB) Viewed 17734 times
- Standard and lowered rear springs
- IMG_20160813_224815.jpg (185.69 KiB) Viewed 17734 times
- Carpet under battery tray
- IMG_20160813_224844.jpg (221.64 KiB) Viewed 17734 times
- After fitting springs. Fronts havnt settled properly yet
- IMG_20160813_224922.jpg (201.86 KiB) Viewed 17734 times
- A dusty spoiler ready to be fitted
- IMG_20160813_224948.jpg (196.69 KiB) Viewed 17734 times
- Spoiler fitted
- IMG_20160813_225016.jpg (203.17 KiB) Viewed 17734 times
- Suspension settled in restaurant car park
- IMG_20160813_225046.jpg (183.65 KiB) Viewed 17734 times
Today I cut out a little more rust on the scuttle. 4 hours later and it's all solid metal again and I treated myself to some russet brown paint. It will need more flatting off when whole car gets resprayed but I'm impressed with how it's turned out.
- Rusted all the way along
- IMG_20160814_215323.jpg (192.97 KiB) Viewed 17713 times
- Rust cut out. Lots of flakes off outer skin but the inner pannel are still solid
- IMG_20160814_215350.jpg (181.05 KiB) Viewed 17713 times
- Over size section made. Cut slot so it will follow the curve
- IMG_20160814_215428.jpg (130.91 KiB) Viewed 17713 times
- Tacked along bottom edge. Had to cut vertical slots to allow pannel to follow firewall shape
- IMG_20160814_215515.jpg (177.84 KiB) Viewed 17713 times
- Closed the bonnet to check the gap
- IMG_20160814_215553.jpg (150.72 KiB) Viewed 17713 times
- Held panel in right place whilst tacking from the back
- IMG_20160814_215636.jpg (154.01 KiB) Viewed 17713 times
- Too ground down flush. I used an arc welding rod to fill the gap and give the edge some strength. Short lengths of rod layer in the gap then MIG welded in
- IMG_20160814_215705.jpg (210.02 KiB) Viewed 17713 times
- Panel welded in
- IMG_20160814_215745.jpg (179.35 KiB) Viewed 17713 times
- Welds ground down
- IMG_20160814_215817.jpg (178.55 KiB) Viewed 17713 times
- Filler applied
- IMG_20160814_215843.jpg (158.54 KiB) Viewed 17713 times
More pics from today
- Filler sanded down
- IMG_20160814_215911.jpg (157.54 KiB) Viewed 17713 times
- Zinc primer applied
- IMG_20160814_215937.jpg (145.44 KiB) Viewed 17713 times
- Painted russet brown. When it gets dirty and fades it will match the rest of the car
- IMG_20160814_220009.jpg (156.46 KiB) Viewed 17713 times
- Impressed myself with the pannel gaps
- IMG_20160814_220039.jpg (159.35 KiB) Viewed 17713 times
- Finished
- IMG_20160814_220135.jpg (153.17 KiB) Viewed 17713 times
I see you have managed to buy yet another shade of Russet brown! Nice work though mate, takes courage to take on that panel with nothing more than a sheet of steel and a pair of tinsnips!
Don't be upset about the colour match though, I'm convinced that every Russet car is a slightly different shade (sometimes several slightly different shades) there are at least 6 factory shades, then there is fading, cos Russet has a lot of red in it! When I used to paint, back in the day, I only ever ordered 1/2 a litre of Russet, cos I knew that by the time the paintshop had finished tinting it to match, i'd have enough to paint the whole car!
I've found telling myself it's a customers car helps when cutting big holes in the body work otherwise I would never have the courage to do it! Just got to work my way round the rest of the car now. I'm not fussed about what shade of russet brown at the moment coz it will have a complete respray at some point.Carledo wrote:I see you have managed to buy yet another shade of Russet brown! Nice work though mate, takes courage to take on that panel with nothing more than a sheet of steel and a pair of tinsnips!
This weekend I got fed up of pumping the tyres up so I got the steel wheels out and cleaned and painted the sealing faces of the rims. I took the tyres off the sprint alloys and fitted to the steel rims. They're a bit crusty on the outside but they hold air which the alloys didn't do anymore.
- Paint peeling off the sealing faces
- IMG_20160821_201247.jpg (193.92 KiB) Viewed 17608 times
- Look crusty but hold air.
- IMG_20160821_201155.jpg (172.45 KiB) Viewed 17608 times
Going for the sleeper look? Or just laziness?
