sprint engine numbers
hi just picked up a sprint engine with engine number va 3424 ess. whats ess mean any ideas thanks dick
Re: sprint engine numbers
IIRC its the code for a factory rebuilt engine.
Only the H is probably removed.
- GrahamFountain
Anybody seen a CHxxxHE numbered Sprint block?
Half guess, half gut feeling, is that not a TR7 block code?GrahamFountain wrote:Anybody seen a CHxxxHE numbered Sprint block?
Nothing wrong with your gut.
Tr7 engine number.
Jeroen.
Tr7 engine number.
Jeroen.
- GrahamFountain
No. TR7 blocks are numbered CG, not CH. And this is a number for a 16-valve Sprint engine.
TR7 Sprint?
CHxxxxHE is TR7 Sprint.
Pretty rare engine then!
- GrahamFountain
Yes, they are TR7 Sprint engine numbers. The engine numbers I know of go from CH2 to CH117. But I've only about 35 numbers in that range, mostly for the 30 SJW press garage cars, all from cars built in 1977. You might well as why they needed 30 TR7 Sprints at the press garage! Though there is a story of a batch of engines went to Speke and were never seen again. Whether they're inside that range or not, I don't know.
At least it has a number, my factory replacement engine doesn't have one!
1962 Austin Mini (project)
1962 MGA 1600 Mark II
1965 Mobylette SP50 (project)
2001 Rover 75 2.5-litre V6
