How bad is my Sprint?
shaunroche
Re: How bad is my Sprint?
#346 Post by shaunroche »
Thanks chaps! There's a few more decals to go on but nearly there.
Planning on going Tony but I might be working away so we'll see.
Ron1966
#347 Post by Ron1966 »
Agree with all the other comments it looks fantastic. Hope you can make Dolly Day so I can view it. Well done Shaun.
misterp
#348 Post by misterp »
Thats superb.
Well done and now....foot down and enjoy it :)
#349 Post by xvivalve »
Had I created that, I'd be too scared to drive it!
shaunroche
#350 Post by shaunroche »
Thank you very much chaps!
Planning on going to Wiltshire but I won't know for another week yet....
bodgerben
#351 Post by bodgerben »
That looks the mutts Shaun :)
misterp
#352 Post by misterp »
Hi Shaun,
Did you ever get to the bottom of the gearbox/thrust bearing noise?
shaunroche
#353 Post by shaunroche »
misterp wrote:Hi Shaun,
In a word, no.
When the car is started in neutral for the first time, the gearbox sounds quite normal.
Depress the clutch and bring it back up again and the grumbling noise starts.....I'm assuming it's the release bearing .....
misterp
#354 Post by misterp »
Hi Shaun.....Interesting..
Although mine has now quietened down now, I had a similar noise when I first mated the newly rebuilt engine and gearbox up.
I think mine was the new spigot bush rotating in the crank rather than the gearbox shaft turning inside it. I noticed when I installed it that it was a light press fit in the crank and tighter (not overly so however) fit on the input shaft on the gearbox.
I think that its now had time to wear in that the bush is now staying put in the crank and doing what it should do.
From memory it started to make a noise when the clutch was pressed. Makes sense as it would be when the gearbox input shaft would be static (assuming its in gear) and crank rotating.
All quiet now, so fingers crossed thats all it was..perhaps similar to yours?
shaunroche
#355 Post by shaunroche »
Swapped the tyres to the new minilites today and chatted about getting it MoT'd first week of April so things are moving again!
Speaking of moving.....
Will be doing spanner checks over the next few weeks and fitting a 1 litre oil catch tank to the crankcase breather to comply with the MSA competition car rules, sorting the front bumper and towing brkt and then we should be go to go!
Tony Burd
#356 Post by Tony Burd »
Very Nice, love the side pipe. 8)
Ron1966
#357 Post by Ron1966 »
Love it. Hope it goes as good as it looks. Fantastic result Shaun. Hope to see it at a the national day.
shaunroche
#358 Post by shaunroche »
Cheers chaps!
Think it would look good next to yours Tony at the NEC later in the year!
Not sure about the National meet as I think this is the weekend before the Revival and we're going down there ​the weekend before so might not be able to make it. Will check.
In the meantime, started the crank case breather today......
....and finished the windscreen washer set up.....
shaunroche
#359 Post by shaunroche »
Super Al came round yesterday and tracked the car up adding a little toe in whilst he was at it...... None of that fangled laser aligning malarky for this magician!....
... and​ then off to the MoT station.....
....So finally......
Tony Burd
#360 Post by Tony Burd »
Well done mate and no advisories. My 1st mot they advised no bumpers fitted and number plate on bonnet.
