SU Alloy Spacer Block Studs
ham204
#1 Post by ham204 »
I relieved the TDC shop off a pair of very nice alloy spacer blocks ( at a price of course) and was sent the stuff with eight studs.
They are far too long to fit the carbs - hence my question is: anyone knows how long they should be to fit in the spacer block and leave enough meat to fit the carbs on? I'm trying to prevent myself having an uneducated guess and having a go at cutting them as that usually ends up in tears.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
Mahesh
Re: SU Alloy Spacer Block Studs
#2 Post by Mahesh »
I got a set of unf/unc studs, and corresponding nuts.
If I remember correctly they were 1 1/4", but will go through my eBay purchases and check.
dursley92
#3 Post by dursley92 »
Just do a test build of the carbs on the blocks with the nuts and washers, then saw the studs off to leave a couple of threads still showing after the nut. Thats how I did mine.
I think some folks use an extra spacer as a thermal isolator but I don't find them necessary.
Russ Cooper
Dursley
UK
ham204
#4 Post by ham204 »
Will do
1972 Spitfire MK IV
1972 Stag
1980 Sprint
#5 Post by Toledo Man »
I've moved the thread here because the OP was asking for advice.
ham204
#6 Post by ham204 »
For records' sake I make out the required length as 32mm which seems to work out fine.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
#7 Post by xvivalve »
The longer studs are fine with earlier carbs; the castings changed shape on later ones.
