1850 cylinder head . Distortion ?
#1 Post by MIG Wielder »
One question for the engine experts please.
If you have an 1850 cylinder head that has got hot and distorted, so it needs a skim, does that also mean the cam should be removed and the camshaft bearings also should be rebored in-line ?
Thanks Tony.
Re: 1850 cylinder head . Distortion ?
#2 Post by xvivalve »
If it has warped to that extent, I'd say it is scrap; any attempt to rebore the cam line bore potentially means each bearing surface becomes eccentric and the cam will no longer sit tight...
#3 Post by xvivalve »
...not that I'm an 'engine expert'!
#4 Post by Carledo »
Distorted so much that it needs a skim can be a couple of thou, this would be fine IMO, much more than 10 thou and i'd be looking for the bin!
#5 Post by MIG Wielder »
Thanks for your comments guys. The head is now dismantled and with just the camshaft installed it turns smoothly and with no high spots. Good !
Onwards to completion.
We'll still get the face skimmed though I reckon.
