Crankshaft pulley nut
new to this
#1 Post by new to this »
Hi
what size socket do i need for the crankshaft pulley nut on a sprint
thanks Dave
Re: Crankshaft pulley nut
#2 Post by Carledo »
1.5" AF
new to this
#3 Post by new to this »
Carledo wrote:1.5" AF
Thanks,ive seen a socket on ebay 1& 5/16 Af is that right
Thanks dave/color]
GTS290N
#4 Post by GTS290N »
No, check your fractions.
1.5 inches is one and a half inches is 1 and 1/2 inches is 1 and 8/16 inches is 1 and 16/32 inches.
1 and 5/16 inches is....1 and 5/16 inches. In other words a wee bit over 1 and 1/4 inches, a most unusual size in my experience.
Check out this site:
Deep one and half inch impact socket six sided and 1/2 drive.Suitable many early English vehicles (BMC mini,Allegro,1100,1300 Maxi etc) and others as ball joint,flywheel and hub nut sockets etc, £11.00p
http://www.baconsdozen.co.uk/tools/af%20sockets.html
I'm not saying this is a suitable socket, simply that it is 1.5"!
Bumpa
#5 Post by Bumpa »
I found that 1 & 1/2" AF sockets with a 1/2" drive are rare. I ended up buying one of these
http://www.ebay.co.uk/itm/142076214282? ... EBIDX%3AIT
The bolt in question is extremely tight, but with my air impact gun it came undone easily.
#6 Post by MIG Wielder »
This is my solution to releasing the crank pulley nut. Its a 3/4 in drive breaker bar and a really solid socket. I have to use a 3/4 to 1/2 in drive adaptor for the torque wrench though.
1 point 5 in skt.jpg (89.93 KiB) Viewed 1504 times
new to this
#7 Post by new to this »
Bumpa wrote:I found that 1 & 1/2" AF sockets with a 1/2" drive are rare. I ended up buying one of these
thanks just ordered one
new to this
#8 Post by new to this »
GTS290N wrote:No, check your fractions.
thanks for link,just checking i have the right fan blade, you do have to remove the fan to get to the crankshaft bolt ?
