Testing upper/ lower front ball-joints.
#1 Post by MIG Wielder »
Now I've noticed my 1850's n/s front tyre is starting to wear noticeably on the outer edge. Since its only the one side I suspect wheel bearing or ball joints. Wheel bearing feels O.K. by the wiggle-the-wheel-test, and I understand the upper and lower ball-joints are tested by letting the wheel hang and then trying to lever it upwards gently with a crow-bar and feeling for movement between the moving bit and the fixed bit.
Both joints feel O.K. by this method.
And the car still handles nicely
Is there any other test I can do ?
Thanks,
new to this
Re: Testing upper/ lower front ball-joints.
#2 Post by new to this »
if you have tyre ware,have you checked the tracking
grahamwatson
#3 Post by grahamwatson »
I think Tony is right that it is unlikely to be tracking if the wear is on N/S only.
Tony, do you by chance regularly park on the upper floors of a multi storey car park with a clockwise ramp system?
Triumph1300
#4 Post by Triumph1300 »
Lot of roundabouts?
Is the inner edge of the other tyre worn?
Have a look at your tears.
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
Mahesh
#5 Post by Mahesh »
If it is roundabouts, can it be classed as Milton Keynes syndrome ?
#6 Post by Jon Tilson »
The ball joints should have zero play. If that's the case it isn't them. Try the track rod end.
Also have a look at the inner wishbone to sub frame bush, but this usually causes inner edge wear.
I would still have the tracking checked.
dollyman
#7 Post by dollyman »
Mahesh wrote: Fri Jun 16, 2017 8:34 pm If it is roundabouts, can it be classed as Milton Keynes syndrome ?
it can in a "roundabout" way :lol:
