Chugging Again!
ham204
Chugging Again!
#1 Post by ham204 »
The Sprint is finally idling very sweetly but once I put the engine under load, it starts chugging, as if a plug has gone dead. Idling back it's ok but won't take up speed.
ideas?
It's due for a head recondition and timing chain replacement.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
Re: Chugging Again!
#2 Post by Jon Tilson »
Oil in dashpots or lead or plug breaking down? Insufficient points gap or duff condensor....you name it, it could be loads of things.
Change one thing at a time....:-)
Flyfisherman
Re: Chugging Again!
#3 Post by Flyfisherman »
Fuel starvation
Paul
ham204
Re: Chugging Again!
#4 Post by ham204 »
Flyfisherman wrote: Mon Jun 12, 2017 7:49 pm Fuel starvation
Paul
hmm - that's interesting.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
Flyfisherman
Re: Chugging Again!
#5 Post by Flyfisherman »
Mario
Check the bottom of the float bowls for dirt / debris etc - this could reduce the quantity of fuel going to the jets, whilst on tick over its fine but when more fuel is requires it could be resticting the flow - assuming you have SU carbs.
Paul
ham204
Re: Chugging Again!
#6 Post by ham204 »
Flyfisherman wrote: Tue Jun 13, 2017 5:17 pm Mario
Paul
Could this be the reason? The SU manual says that the gap should be 0.125 but it's more like 3/8 inches. The other one is only slighter better. No adjustment is possible so it seems that the wrong valve/float has been fitted.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
ham204
Re: Chugging Again!
#7 Post by ham204 »
Problem solved - PO fitted a washer which, once removed, let the float higher in the chamber. Will check whether this makes a difference to the 'chugging'
1972 Spitfire MK IV
1972 Stag
1980 Sprint
Re: Chugging Again!
#8 Post by soe8m »
That angle is not good of your float. The base has to be level or a tiny bit going up. I do sand a fiber washer to size to have the correct angle. Also the floatneedles come in sizes. A sprint does need the larger size. There are many parts in su's that look identical but are not and are easily mixed up.
ham204
Re: Chugging Again!
#9 Post by ham204 »
Had the Sprint sent to a mechanic friend as I could not solve the severe tapping issue that it had. Within 30 minutes he phoned and said that problem solved - a shim had fallen out and led to the tapping noise! How the hell could that happen (the shim falling out I mean)? It never occurred to me to have a look around the cylinder head.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
