Sprint Bulkhead Sound Deadening
Hi Does anyone know where I can get a Sound Deadening Panel for the Engine Bay Bulhead on the Sprint I an restoring, or the material to cut one out.
Re: Sprint Bulkhead Sound Deadening
Try a PM to user SprintMWU773V
I think he had some made and may well have one left.
I recently had one made up by Aldridge trimming. They already had a pattern for a standard dolomite but i sent them my old sprint one to copy as sprint ones are slightly different (something to do with the manifold I believe). I can't remember the exact cost but £50 is probably not far off.
Simon
Simon
- soundpad.jpg (89.26 KiB) Viewed 1448 times
Excellent I will order one tomorrow from them many thanks.
- SprintMWU773V
- TDC Staffs Area Organiser
I gave Aldridge Trimming an original but damaged 1850 one to use as a template which they then digitised so anyone can now order one. The Sprint one has a cut out for the exhaust heat shield but is otherwise the same.
I sold out in 2012!
I sold out in 2012!
Many thanks guys got one from Aldridge Trimming, excellent product & fit. Total cost including postage to Highlands £70.
Do you know the material its made from?. I removed mine when I did engine bay respray and wasnt sure about refitting one if it was a water trap like the originals. If its closed cell foam it should be ok.
- SprintMWU773V
The MK1 they made up was open cell but I later specified closed cell foam
John (JTSprint) bought & fitted one recently. Maybe he can tell us?
It looks more like a cross between a Rubber & Foam quite dense.
