Sprint Bulkhead Sound Deadening
dolly519
#1 Post by dolly519 »
Hi Does anyone know where I can get a Sound Deadening Panel for the Engine Bay Bulhead on the Sprint I an restoring, or the material to cut one out.
Re: Sprint Bulkhead Sound Deadening
#2 Post by Jon Tilson »
Try a PM to user SprintMWU773V
I think he had some made and may well have one left.
dolly519
#3 Post by dolly519 »
Thanks for that
OBJ
#4 Post by OBJ »
I recently had one made up by Aldridge trimming. They already had a pattern for a standard dolomite but i sent them my old sprint one to copy as sprint ones are slightly different (something to do with the manifold I believe). I can't remember the exact cost but £50 is probably not far off.
Simon
dolly519
#5 Post by dolly519 »
Excellent I will order one tomorrow from them many thanks.
SprintMWU773V
TDC Staffs Area Organiser
#6 Post by SprintMWU773V »
I gave Aldridge Trimming an original but damaged 1850 one to use as a template which they then digitised so anyone can now order one. The Sprint one has a cut out for the exhaust heat shield but is otherwise the same.
I sold out in 2012!
dolly519
#7 Post by dolly519 »
Many thanks guys got one from Aldridge Trimming, excellent product & fit. Total cost including postage to Highlands £70.
#8 Post by tony g »
Do you know the material its made from?. I removed mine when I did engine bay respray and wasnt sure about refitting one if it was a water trap like the originals. If its closed cell foam it should be ok.
dolly519 wrote: Sat Nov 11, 2017 8:09 am Many thanks guys got one from Aldridge Trimming, excellent product & fit. Total cost including postage to Highlands £70.
SprintMWU773V
#9 Post by SprintMWU773V »
The MK1 they made up was open cell but I later specified closed cell foam
#10 Post by Mad Mart »
John (JTSprint) bought & fitted one recently. Maybe he can tell us?
dolly519
#11 Post by dolly519 »
It looks more like a cross between a Rubber & Foam quite dense.
