Carburettors
new to this
Carburettors
#1 Post by new to this »
Hi
I would like to order some carburettor mounts,looked on the parts list,they show 1 7/5 and 2 inch,i think mine are 2inch but how do i measure them to be sure,also do i need O rings with these carb mounts ?
thanks for any help Dave
Re: Carburettors
#2 Post by xvivalve »
Standard HS6 carbs are 1.75"
You need to measure the diameter of the throat of the carburettor body.
Alternatively, if there is still a small ID tag held beneath one of the float chamber lid screws, post what code is stamped on it and we'll tell you what the carbs are.
The carb mounts are one of the parts we still carry, and I believe they come supplied with O rings.
new to this
Re: Carburettors
#3 Post by new to this »
xvivalve wrote: Fri Aug 25, 2017 9:14 pm Standard HS6 carbs are 1.75"
Alun
thanks ill measure them tomorrow,do you know if you have them in stock
Re: Carburettors
#4 Post by xvivalve »
I don't, sorry Dave, it's not one of the lines I'm involved in. An e-mail enquiry to tdcspares should elicit a prompt answer though.
Re: Carburettors
#5 Post by Mad Mart »
The 1.75" alloy mounts for the standard Sprint carbs come complete with 'O' rings. They are on order but not sure when they will be here.
new to this
Re: Carburettors
#6 Post by new to this »
Had a look yesterday but couldnt find any tags
thanks Dave
new to this
Re: Carburettors
#7 Post by new to this »
Mad Mart wrote: Sun Aug 27, 2017 12:48 am The 1.75" alloy mounts for the standard Sprint carbs come complete with 'O' rings. They are on order but not sure when they will be here.
thanks,did you see the photos of mine,what are they 1.75 or 2
thanks Dave
Re: Carburettors
#8 Post by xvivalve »
They look like HS8 (2") possibly, as both float chambers are to the rear. Measure the diameter of the throat to be certain.
Re: Carburettors
#9 Post by Jon Tilson »
Pair of HD8's there either off a Jag ( I hope) or a Rover 2000TC ( wrong for a dolly unless well modified
The club mounts will not work as these are two inches.
I suspect the Rover origin due the the fuel connection, which looks more Rover-ish plus the Jag has a starting carb fitment.
Could be wrong though?
How do they run?
Re: Carburettors
#10 Post by Mad Mart »
The club sell the 2" version as well but I would have to order them.
new to this
Re: Carburettors
#11 Post by new to this »
Jon Tilson wrote: Sun Aug 27, 2017 11:49 am Pair of HD8's there either off a Jag ( I hope) or a Rover 2000TC ( wrong for a dolly unless well modified
How do they run?
They were on the car when I bought it ,so don't know how well they run,not had the engine running yet
new to this
Re: Carburettors
#12 Post by new to this »
Mad Mart wrote: Sun Aug 27, 2017 11:56 am The club sell the 2" version as well but I would have to order them.
Mart
Do you know how long it would be to have them in stock ?
new to this
Re: Carburettors
#13 Post by new to this »
xvivalve wrote: Sun Aug 27, 2017 10:51 am They look like HS8 (2") possibly, as both float chambers are to the rear. Measure the diameter of the throat to be certain.
Do you have to take the carb off the manifold to be able to measure the diameterof the throat
Re: Carburettors
#14 Post by Jon Tilson »
No need....they are HD8's.
8 = 2 inches in SU parlance....
6 = 1.75 inches
4 = 1.5 inches.
new to this
Re: Carburettors
#15 Post by new to this »
Jon Tilson wrote: Sun Aug 27, 2017 8:53 pm No need....they are HD8's.
6 = 1.75 inches
4 = 1.5 inches.
