Carburettors
Carburettors
Hi
I would like to order some carburettor mounts,looked on the parts list,they show 1 7/5 and 2 inch,i think mine are 2inch but how do i measure them to be sure,also do i need O rings with these carb mounts ?
thanks for any help Dave
Re: Carburettors
Standard HS6 carbs are 1.75"
You need to measure the diameter of the throat of the carburettor body.
Alternatively, if there is still a small ID tag held beneath one of the float chamber lid screws, post what code is stamped on it and we'll tell you what the carbs are.
The carb mounts are one of the parts we still carry, and I believe they come supplied with O rings.
Re: Carburettors
Alunxvivalve wrote: ↑Fri Aug 25, 2017 9:14 pm Standard HS6 carbs are 1.75"
thanks ill measure them tomorrow,do you know if you have them in stock
Re: Carburettors
I don't, sorry Dave, it's not one of the lines I'm involved in. An e-mail enquiry to tdcspares should elicit a prompt answer though.
Re: Carburettors
The 1.75" alloy mounts for the standard Sprint carbs come complete with 'O' rings. They are on order but not sure when they will be here.
Re: Carburettors
They look like HS8 (2") possibly, as both float chambers are to the rear. Measure the diameter of the throat to be certain.
Re: Carburettors
Pair of HD8's there either off a Jag ( I hope) or a Rover 2000TC ( wrong for a dolly unless well modified
The club mounts will not work as these are two inches.
I suspect the Rover origin due the the fuel connection, which looks more Rover-ish plus the Jag has a starting carb fitment.
Could be wrong though?
How do they run?
How do they run?
Re: Carburettors
The club sell the 2" version as well but I would have to order them.
Re: Carburettors
JonnersJon Tilson wrote: ↑Sun Aug 27, 2017 11:49 am Pair of HD8's there either off a Jag ( I hope) or a Rover 2000TC ( wrong for a dolly unless well modified
How do they run?
They were on the car when I bought it ,so don't know how well they run,not had the engine running yet
Re: Carburettors
No need....they are HD8's.
8 = 2 inches in SU parlance....
6 = 1.75 inches
4 = 1.5 inches.
6 = 1.75 inches
4 = 1.5 inches.
Re: Carburettors
JonnersJon Tilson wrote: ↑Sun Aug 27, 2017 8:53 pm No need....they are HD8's.
6 = 1.75 inches
4 = 1.5 inches.
