Hi all,
I bought a second-hand Spring engine recently. I plan to turn it over - does anyone know what size spanner/ socket I'll need please? Any help much appreciated.
Turning over engine
Re: Turning over engine
38mm socket fits on crank pulley, should be able to turn it over with a decent size bar, maybe a longish spanner. It can be a bit of a struggle when you're fighting the engines compression. Removing the spark plugs would obviously make it easier.
Inch and a half.
I had the same problem,bought a socket,but it would be nice if they sold a offset spanner to fit,as when the fan is in place the socket doesnt fit ?
