Turning over engine
richphy
Turning over engine
#1 Post by richphy »
Hi all,
I bought a second-hand Spring engine recently. I plan to turn it over - does anyone know what size spanner/ socket I'll need please? Any help much appreciated.
cleverusername
Re: Turning over engine
#2 Post by cleverusername »
richphy wrote: Tue Sep 05, 2017 9:03 am Hi all,
38mm socket fits on crank pulley, should be able to turn it over with a decent size bar, maybe a longish spanner. It can be a bit of a struggle when you're fighting the engines compression. Removing the spark plugs would obviously make it easier.
#3 Post by xvivalve »
Inch and a half.
new to this
#4 Post by new to this »
I had the same problem,bought a socket,but it would be nice if they sold a offset spanner to fit,as when the fan is in place the socket doesnt fit ?
richphy
#5 Post by richphy »
Thanks for all the responses, much appreciated.
Karlos
#6 Post by Karlos »
xvivalve wrote: Tue Sep 05, 2017 7:30 pm Inch and a half.
Or 1.5" if you are metricated. Not 38mm, although it will fit 😊
