Brake Broke - now I am broke!
GTS290N
#1 Post by GTS290N »
Despite the car passing the rolling road MOT, for the past couple of years I've been suspicious about the brakes in emergency situations.
This is my latest attempt to cure this, I have a feeling this story will run and run...
The new bits (plastic clips are arriving this week from Robsport (numpty9 on eBay)) and this brings the total to £312:
ImageIMG_0488
A close-up of the club refurb'd calipers:
ImageDSC_0017
And what I hope (but doubt) are the root cause:
ImageIMG_0489
Proof that an MOT isn't the safety thing to end all safety things, but I'd still rather have one!
Re: Brake Broke - now I am broke!
#2 Post by xvivalve »
Well, you were only getting about 50% contact with the old disc and pad set up!
#3 Post by soe8m »
The only way to go. And for 312gbp you dont have a new front panel, wings and a new radiator.
Karlos
#4 Post by Karlos »
Would that brake rotor be an MOT fail, or just an advisory?
#5 Post by Carledo »
Karlos wrote: Tue Sep 26, 2017 10:24 pm Would that brake rotor be an MOT fail, or just an advisory?
Advice on what to fail by the ministry varies somewhat. A few years ago those Rotors would have only got an advise, so long as the efficiencies and balance were within limits. Lately however the ministry position (and therefore testers opinion) has altered and even my classic friendly tester would fail them! HOWEVER he could only fail them if he can SEE them! IF, as I believe, that is the inner face, it is pretty well hidden, assuming the outer face looks OK, it could easily slip through the cracks!
SprintMWU773V
TDC Staffs Area Organiser
#6 Post by SprintMWU773V »
But how many 'average' owners whose car becomes MOT exempt next year will bother to inspect their brakes properly?
Karlos
#7 Post by Karlos »
How many indeed! AND even if the owner did inspect their car there will be that added temptation to "let it run for another month, then I'll get around to it and sort it" if there is no pending test due.
new to this
#8 Post by new to this »
It surprising how the disc rust from the back
#9 Post by xvivalve »
Those calipers are sexy beasts though, aren't they? :-D
#10 Post by soe8m »
xvivalve wrote: Thu Sep 28, 2017 8:49 am Those calipers are sexy beasts though, aren't they? :-D
Makes the brake pedal feel hard again Alun?
