Despite the car passing the rolling road MOT, for the past couple of years I've been suspicious about the brakes in emergency situations.
This is my latest attempt to cure this, I have a feeling this story will run and run...
The new bits (plastic clips are arriving this week from Robsport (numpty9 on eBay)) and this brings the total to £312:
Karlos wrote: ↑Tue Sep 26, 2017 10:24 pm
Would that brake rotor be an MOT fail, or just an advisory?
Advice on what to fail by the ministry varies somewhat. A few years ago those Rotors would have only got an advise, so long as the efficiencies and balance were within limits. Lately however the ministry position (and therefore testers opinion) has altered and even my classic friendly tester would fail them! HOWEVER he could only fail them if he can SEE them! IF, as I believe, that is the inner face, it is pretty well hidden, assuming the outer face looks OK, it could easily slip through the cracks!
How many indeed! AND even if the owner did inspect their car there will be that added temptation to "let it run for another month, then I'll get around to it and sort it" if there is no pending test due.
