Identification
RSi
Identification
#1 Post by RSi »
Where are all the places on an 1980 Sprint you will find identification numbers.
Club Membership No: 2017092
Len Hughes
Re: Identification
#2 Post by Len Hughes »
I'm no expert on the later cars but I believe the VIN number is stamped on the boot aperture on the rear screen end not the lock end, also on the plate in the engine bay. I'm sure someone more learned will be along shortly to confirm / correct.
Len
1973 Mimosa Sprint
1973 Magenta TR6
RSi
Re: Identification
#3 Post by RSi »
Len Hughes wrote: Thu Dec 07, 2017 8:24 pm I'm no expert on the later cars but I believe the VIN number is stamped on the boot aperture on the rear screen end not the lock end, also on the plate in the engine bay. I'm sure someone more learned will be along shortly to confirm / correct.
Len
I heard that too but trying to work out exactly where you mean at the rear screen end.
Triumph1300
Re: Identification
#4 Post by Triumph1300 »
Open the boot, and look in the trough of the boot aperture below the rear window
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
RSi
Re: Identification
#5 Post by RSi »
Yes you're right - unfortunately it's a sticker so is warn as you'd expect after 37 yrs, I wonder is there anyone who could remake it. Would like to have one to put back on after the respray.
Where's the engine number on a Sprint engine.
Mahesh
Re: Identification
#6 Post by Mahesh »
It's not a sticker your after, I've seen James's Sprint markings, and they are about 1/2" engraved/embossed lettering.
I'm sure there's a picture in his thread.
RSi
Re: Identification
#7 Post by RSi »
Mahesh wrote: Thu Dec 07, 2017 10:03 pm It's not a sticker your after, I've seen James's Sprint markings, and they are about 1/2" engraved/embossed lettering.
Would like to see that, wonder if I remove this faded yellow sort of laminated sticker what will I find???
TrustNo1
Re: Identification
#8 Post by TrustNo1 »
If you car has the newer style VIN (11 digits, not the VA***DLO number) it will have the number stamped into the boot channel.
Reg
Re: Identification
#9 Post by Reg »
RSi wrote: Thu Dec 07, 2017 11:04 pm
Look from inside the boot, underneath the number and you might well find that they can be read. When stamped at the factory, it breaks what little paint is there and quietly rusts!
RSi
Re: Identification
#10 Post by RSi »
Reg wrote: Tue Dec 12, 2017 11:09 am
Yes, you're right - it is stamped - I cleaned it up and the number is visible on the top too.
