tamtrucks
#211 Post by tamtrucks »
no baffles inside as my metal tank has none either,so tried to keep it the same
did original dolly tanks come with baffles? ive got 77 and 80 both have no baffles
not sure on volume of tank but cant be far off 57L/12.5gallons,il be happy with 50L tank,saves on carrying excess fuel
tamtrucks
#212 Post by tamtrucks »
just measured the tank,and calculated on website convertor that the tank is 44.6L,so lost 12L,that includes the mod to be done
SprintMWU773V
TDC Staffs Area Organiser
#213 Post by SprintMWU773V »
There aren't any baffles as such but there is a small container within the tank where the sender sits which acts as a baffle for the sender unit.
It does look quite nice though I think if I were fitting an alternative tank I'd look to fit a foam filled jobbie for safety, the tank is in just about the worst position in the event of a rear bump.
tamtrucks
#214 Post by tamtrucks »
in my tank there no container at all,tank from the 77 dolly i got
new to this
#215 Post by new to this »
tamtrucks wrote: Fri Oct 06, 2017 4:28 pm in my tank there no container at all,tank from the 77 dolly i got
The reason you would have small container inside the tank by the pick up,is when you get low on fuel,it will slosh about and could loose the fuel around the pick up pipe,and the car could cut out as no fuel would be pumped
#216 Post by Jon Tilson »
AS OE the tank capacity was 12.5 gallons....nice long range at 40 mpg.
There should be baffles around the tank sender flat arm, which makes fitting it a bit of an art, but worthwhile to stop it
flopping up and down too quick as the level drops and the fuel sloshes around.
tamtrucks
#217 Post by tamtrucks »
thanks for comment,,nice one
drop tank off for mods last night,just phoned now-explained,he`s on it
new to this
#218 Post by new to this »
tamtrucks wrote: Sat Oct 07, 2017 3:33 pm thanks for comment,,nice one
[/quot
what's it made from alli or stainless ? It looks nice
tamtrucks
#219 Post by tamtrucks »
alloy 3mm
tamtrucks
#220 Post by tamtrucks »
got the fuel tank back. needs fettling to fit
tamtrucks
#221 Post by tamtrucks »
yesterday,bought a new in box fuel sender unit(2pin)now got a spare,not done nothing to alloy tank as its needs work,may have to buy tig welder :D thinking of selling the red dolly on :( but browny is still good,rear window demister works 8) now done 63600`ish since i got it
tamtrucks
#222 Post by tamtrucks »
well,its been a while since last post
not much has happened since still the same,but over the past month few problems
steering knuckle lower part rubbers were gone,cracked and few have gone somewhere :shock: got new poly`s ready to fit,but for now carmine-dolly has no steering,browny spot on now 8)
then...the drivers bottom ball joint start making a noise,changed that from carmine-dolly and all mint,got new ones here ready to fit,but first...mod to fit grease nipple
thats it for now :bluewave:
going_downhill
#223 Post by going_downhill »
Any luck with your alloy tank?
1980 Russet 1850hl
tamtrucks
#224 Post by tamtrucks »
yeah got an alloy built,not to original spec even tho a spare one was given as template but it the shape`ish of one,no pick up tube but there is a feed out and its flat bottomed.....so all in all its a start of something
tamtrucks
#225 Post by tamtrucks »
just tidy`d up the driver side bottom doors and rear arch,need cutting back to blend in
