Removing the crank pulley without using the starter
cleverusername
#1 Post by cleverusername »
Basically I tried that method and the chain jumped off the top pulley, so I can't turn it over without causing chaos and carnage.
Has anyone got any bright ideas? Sprint engine.
yorkshire_spam
Re: Removing the crank pulley without using the starter
#2 Post by yorkshire_spam »
Ooooh nasty. What's the clearance like at the front? Any chance of getting an air impact gun on it?
I'd be starting to think timing gear off to prevent anything happening to the valves etc. but that's a serious faff.
cleverusername
#3 Post by cleverusername »
yorkshire_spam wrote: Sun Mar 11, 2018 12:37 pm Ooooh nasty. What's the clearance like at the front? Any chance of getting an air impact gun on it?
Oh the valves are OK, the head is in the garage.
Alas my father took a look at the problem and said use the starter it will be fine. The pulley is off and the front engine over is now shattered at the bottom. Guess what I am looking for now? Oh well.
Magenta Auto Sprint
#4 Post by Magenta Auto Sprint »
if the head is off, it my be easy to remove the starter motor, use a thick blade screw driver to fit in the starter ring gear and the bell housing, it has to be in the right place for the direction of rotation, a two person job as well.
Malc
#5 Post by tony g »
If 2 people are there, stick in 4th gear and have someone press the brake hard while you swing on the bar :)
PaulB
#6 Post by PaulB »
Take off the sump and wedge the crank with a block of wood.
cleverusername
#7 Post by cleverusername »
It is off and rebuilt, blew up the front cover alas and found the half moon seal had fallen into the pulleys. So an expensive lesson, but it could have been worse.
#8 Post by tony g »
Which method worked then?
SprintMWU773V
TDC Staffs Area Organiser
#9 Post by SprintMWU773V »
PaulB wrote: Mon Mar 12, 2018 5:40 pm Take off the sump and wedge the crank with a block of wood.
Seconded
