Removing the crank pulley without using the starter
Basically I tried that method and the chain jumped off the top pulley, so I can't turn it over without causing chaos and carnage.
Has anyone got any bright ideas? Sprint engine.
- yorkshire_spam
Re: Removing the crank pulley without using the starter
Ooooh nasty. What's the clearance like at the front? Any chance of getting an air impact gun on it?
I'd be starting to think timing gear off to prevent anything happening to the valves etc. but that's a serious faff.
Oh the valves are OK, the head is in the garage.yorkshire_spam wrote: ↑Sun Mar 11, 2018 12:37 pm Ooooh nasty. What's the clearance like at the front? Any chance of getting an air impact gun on it?
Alas my father took a look at the problem and said use the starter it will be fine. The pulley is off and the front engine over is now shattered at the bottom. Guess what I am looking for now? Oh well.
if the head is off, it my be easy to remove the starter motor, use a thick blade screw driver to fit in the starter ring gear and the bell housing, it has to be in the right place for the direction of rotation, a two person job as well.
Malc
Malc
If 2 people are there, stick in 4th gear and have someone press the brake hard while you swing on the bar
Take off the sump and wedge the crank with a block of wood.
It is off and rebuilt, blew up the front cover alas and found the half moon seal had fallen into the pulleys. So an expensive lesson, but it could have been worse.
Which method worked then?
- SprintMWU773V
- TDC Staffs Area Organiser
Seconded
