Fibreglass Wings
ham204
Fibreglass Wings
#1 Post by ham204 »
Do the TDC fibreglass wings have to be glued on to the rest of the car? Can they be bolted instead, for easy removal?
If gluing is the only way, which glue to use?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
1962 Land Rover Series 2a
1983 Land Rover Series 3
1995 Suzuki Samurai SJ413
James467
TDC Sprint Registrar
Re: Fibreglass Wings
#2 Post by James467 »
I was thinking the same. The problem is fitting bolts to the seam on the a post.
Steve has used tigerseal to glue them on.
ham204
#3 Post by ham204 »
I'll check how my Land Rover wings are fitted. I think they had a small bracket at the back to bolt to.
1972 Spitfire MK IV
1972 Stag
1980 Sprint
ham204
#4 Post by ham204 »
James467 wrote: Thu Mar 15, 2018 4:12 pm I was thinking the same. The problem is fitting bolts to the seam on the a post.
I suppose you cannot dismantle them then right?
1972 Spitfire MK IV
1972 Stag
1980 Sprint
#5 Post by xvivalve »
Nuts and bolts, self tappers, rivets, tiger seal, a combination of several, or all of them!
The GRP wings have a flange to meet with the A post flange exactly the same as the original.
TrustNo1
#6 Post by TrustNo1 »
If using Speedbolts/ self tappers or similar could these be used on the Apost flange with spacer plates to spread the load?
https://www.ebay.co.uk/itm/Mudflap-Fitt ... 1MaBADitMw
don't need to do the job just thinking out loud.
#7 Post by Carledo »
I use a combination of self drilling tapping bolts and Tiger seal to install the GRP panels.
I just use the tapping bolts to do all the try fitting and fettling, then when i'm satisfied with the fit, I remove the panel entirely, add a generous dollop of Tiger seal to all the mating flanges and rebolt them on so the sealer dries in place. Once dry, the screws CAN be removed and the holes filled, but being a "belt and braces" engineer, I just leave the screws in as well! I've found you don't need screws in the door shut area, the shape of the club panel is close enough to original that screws at top and a couple at the bottom will hold it correctly whilst the sealant sets. The same goes for the almost impossible to access seam between the wing and the upper outer front panel.
Panels attached in this fashion CAN be removed, undo the screws and cut the sealant away carefully with a breadknife! But so long as you've fitted them right, the only reason you'd ever NEED to remove one is for accident damage - and then you don't CARE if the old one comes off in bits!
#8 Post by MIG Wielder »
When Derek did my O/S wing 4 years ago he used a mixture of MGB wing fixings along the top and bottom edges and Tiga-Seal(?) on the rest. The special washers are AFH2546. Can't see the bolts right now.
If you'd like a look-see at mine, please do let me know.
cleverusername
#9 Post by cleverusername »
I just drilled holes and bolted them on. This will leave gaps, which sealant would fill, but easy removalability is what I wanted most. Which has paid off, I had to weld one corner of the windscreen. Taking the wing off involved removing a dozen bolts, compared to cutting through endless spot welds on a normal car.
ham204
#10 Post by ham204 »
cleverusername wrote: Sat Mar 17, 2018 10:24 am I just drilled holes and bolted them on. This will leave gaps, which sealant would fill, but easy removalability is what I wanted most. Which has paid off, I had to weld one corner of the windscreen. Taking the wing off involved removing a dozen bolts, compared to cutting through endless spot welds on a normal car.
This is what I meant. Thank you
1972 Spitfire MK IV
1972 Stag
1980 Sprint
ham204
#11 Post by ham204 »
ham204 wrote: Thu Mar 15, 2018 4:23 pm I'll check how my Land Rover wings are fitted. I think they had a small bracket at the back to bolt to.
Not much joy - they have a bolt on top of the mudguard just below the windscreen - very unsightly for a less 'tractor like' car!
1972 Spitfire MK IV
1972 Stag
1980 Sprint
#12 Post by MIG Wielder »
As promised to Bill, here is how mine are fitted.
Prep; and paint wise I'd have a word with Derek on here. I know he is quite busy at present so a quick answer might be forthcoming from your local Lotus spray-shop. Derek certainly got a nice finish on mine with no trouble.
As I think I mentioned the fixings are MGB front wing fixings. The rear edge is Tigasealed.
top view fixings.jpg (70.74 KiB) Viewed 2117 times
Lower rear edge.jpg (109.69 KiB) Viewed 2117 times
Lower front inner.jpg (118.55 KiB) Viewed 2117 times
Inner rear edge.jpg (69.98 KiB) Viewed 2117 times
cleverusername
#13 Post by cleverusername »
On the flange by the door you can just use self taping bolt, they are more than man enough to get through the flange and it saves complicated lining up to drill holes with the wings off.
ham204
#14 Post by ham204 »
cleverusername wrote: Wed Mar 28, 2018 2:16 pm On the flange by the door you can just use self taping bolt, they are more than man enough to get through the flange and it saves complicated lining up to drill holes with the wings off.
:clapping:
1972 Spitfire MK IV
1972 Stag
1980 Sprint
#15 Post by xvivalve »
Can we use the expression 'man enough' these days? Might it not offend those mentally ill who consider themselves to be perhaps too manly...?
