PFX 37W Dolomite 1500 restoration
LJColeman
Re: PFX 37W Dolomite 1500 restoration
#16 Post by LJColeman »
A little more done on this one over the last week.
All coolant hoses now replaced
Coolant pipe from water pump to rear replaced
Fuel filter replaced
Almost ready for MOT next weekend!
Also sent the radiator off and had it refurbished by Aarow Radiators in Bristol & what a fantastic job they have done.
#17 Post by Carledo »
LJColeman wrote: Tue Jun 05, 2018 3:05 pm
Carledo wrote: Tue Jun 05, 2018 9:08 am Sorry to burst your bubble, but on your W reg car, at least one rear foglight is mandatory!
No bubbles burst here! Where theres a will theres a way! ;)
Well I guess you could put a red bulb in the o/s reverse light!
Richard the old one
#18 Post by Richard the old one »
If you move the rear fog light from the near side to the off side you will meet the MoT requirements as I believe the requirement is to have at least one on the off side for cars of the that age. The wiring should be there as when new the car will have been fitted with two, one each side. The fog lights are fed via a short bit of loom from the main rear loom. Just a singe cable feed connector and an earth.
Russetauto
#19 Post by Russetauto »
Mandatory fog light needs to be from center of vehicle or to the offside. Just the one anywhere from centre line is acceptable. Check my MOT tester bs!! Lol
LJColeman
#20 Post by LJColeman »
A little more done on the car today - even went on it’s Maiden Voyage. First drive in 18 years, seemed to go well after a little carb tuning. Wheel alignment needs a tweak but other than that we are good to go!
dollyman
#21 Post by dollyman »
Looking really good, apart from the missing rear fog lights :lol: You will remember that drive for a long time :D
#22 Post by soe8m »
One of my customers wanted an extra fog lamp and i did spray one reverse lamp red with translucent red paint. Fitting a red bulb behind a clear glass will have a pinkish glare, not the bright red of a foglamp.
LJColeman
#23 Post by LJColeman »
MOT all booked in for Saturday & then hopefully give her a good run Sunday along with my other Dolly for Fathers day!
yorkshire_spam
#24 Post by yorkshire_spam »
LJColeman wrote: Mon Jun 11, 2018 3:17 pm MOT all booked in for Saturday & then hopefully give her a good run Sunday along with my other Dolly for Fathers day!
Best of luck! In a fit of optimism I booked Binny (RUK) in for her test first thing on Saturday morning!
LJColeman
#25 Post by LJColeman »
yorkshire_spam wrote: Mon Jun 11, 2018 3:26 pm
You’ve got to have something to work towards haven’t you! I’ve been through the car front to back and back to front so should be all ok. + I’m a ex mot tester so I don’t think I’ve missed anything!
LJColeman
#26 Post by LJColeman »
MOT all done & passed. Only 2 advisories on the front upper balljoint gaitors (I was already aware i needed to do these)
However i did come across a few issues on the 25 minute journey to work. First 5 mins went smoothly and the car felt great, Then when up to temp and put my foot down the car bogged down and died. Pulled over, Fired straight back up and runs perfectly at idle. I did however notice when it died on me the fuel filter was empty and i could see bubbles (Like there was a lack of supply or something)
So im going to change the fuel pump this afternoon & change the rubber fuel pipe hoses under the car and see how we get on.
yorkshire_spam
#27 Post by yorkshire_spam »
LJColeman wrote: Sat Jun 16, 2018 10:50 am MOT all done & passed. Only 2 advisories on the front upper balljoint gaitors (I was already aware i needed to do these)
Something worth checking in my experience.... is the filter sealing correctly? I had one on the spitfire where the seals shrank when the car was stood.... the pump ended up pulling more air than fuel!
Good news on the pass..... I got a fail! :roll:
LJColeman
#28 Post by LJColeman »
Panic over all fixed!!
I pulled the pipe off that comes out if the tank at the back & nothing came out!!! The car had a full tank of fuel so ive drained that out & unblocked the tube at the bottom of the tank (Inside of tank looks extremely good and not rusty at all)
Put a new hose on and went for a drive - All good!!
yorkshire_spam
#29 Post by yorkshire_spam »
LJColeman wrote: Sat Jun 16, 2018 11:12 am Panic over all fixed!!
Result!
LJColeman
#30 Post by LJColeman »
yorkshire_spam wrote: Sat Jun 16, 2018 11:16 am
Result!
Indeed very pleased. Nice to have it on the road after 18 years of being sat in a garage!
