Waterpump stuck solid
RON13R
#1 Post by RON13R »
Hi everyone I'm trying to remove a waterpump from my Stag but it is stuck solid
It does have the same pump than your slant fours
Has anyone ever had this problem?
I have posted this on the stag forum but no replies yet
I have made up a slide hammer with bits n bobs but it's not shifting
https://youtu.be/WJD0svpO6_A
I worried I might damage the jackshaft with to much hammering
Getting desperate now lol
Any help would be appreciated
Gaz
Triumph1300
Re: Waterpump stuck solid
#2 Post by Triumph1300 »
Get a bigger weight on the slide hammer, mine looks to be about 3 times heavier than that
BWJ
1966 Triumph 1300 Royal Blue
1966 Triumph 2000 Blue
1967 BSA B40wd green
2018 Jaguar E pace 2018
RON13R
#3 Post by RON13R »
Yes I needed a bigger tool lol
Thanks Triumph 1300
https://youtu.be/Gbi8uj98tvY
TrustNo1
#4 Post by TrustNo1 »
I done the 1850 pump today, I welded a length of rod to the LH thread bolt and a weight to act as a slide hammer, popped out quiet easily after lots of other failed attempts
Now how do I get the brass cage out?
#5 Post by Mad Mart »
With something like this:-
#6 Post by xvivalve »
The 'strips' need to be quite robust!!
TrustNo1
#7 Post by TrustNo1 »
Cheers Mart and Alun I did think it would be something along those lines.
#8 Post by tony g »
Mart did you create that drawing? if so what with? :)
Mad Mart wrote: Fri Jan 11, 2019 8:07 pm With something like this:-
#9 Post by Mad Mart »
I used AutoCAD. It was only a quick lashup. I can do a nice 3D drawing in Fusion 360 if you like. :wink:
#10 Post by tony g »
Clever :). I was hoping non cad types like me could do it on just a pc with no hassle.(cad screens are too involved for me lol)
Mad Mart wrote: Mon Jan 14, 2019 12:41 am I used AutoCAD. It was only a quick lashup. I can do a nice 3D drawing in Fusion 360 if you like. :wink:
Bumpa
#11 Post by Bumpa »
On my 1850 getting the brass cage out was harder than removing the pump!. I made up a tool similar to the one in the drawing and Alun is dead right, the strips need to be strong. I used some thickish steel strips but they still bent before the damn thing finally gave up and came out. Its only held in with two rubber rings so it seems unfeasible that it could be stuck so tightly.
TrustNo1
#12 Post by TrustNo1 »
well that was easy once the extraction tool was made it slid out in a few seconds.
slide hammer made using a weight off another slide and the LH bolt welded on threaded bar.
Cage extractor is a long bolt with a cut down piece of scrap metal I had and a cut down Austin bumper iron.
#13 Post by MIG Wielder »
tony g wrote: Mon Jan 14, 2019 6:13 am Clever :). I was hoping non cad types like me could do it on just a pc with no hassle.(cad screens are too involved for me lol)
I don't want to detract from Mart's absolutely excellent CAD drawing, but if you just want an electronic format mecchy drawing to give to a supplier it is possible to do the same thing with just Powerpoint running under XP.
Naturally it doesn't have all the clever CAD stuff behind the drawing that manufacturer's can use. It is just a picture. Here it is exported as a .jpg
Water Pump Removal Tool.jpg (39.98 KiB) Viewed 1387 times
