Where is/are the drain for the heater intake?
Bumpa
#1 Post by Bumpa »
I can't see any sort of outlet for water that collects there. In my photo, is the drain somewhere under the speedo cable or nearer to the heater pipe?
Drain for Heater Intake.jpg (109.47 KiB) Viewed 830 times
mahony
Re: Where is/are the drain for the heater intake?
#2 Post by mahony »
There are several small holes which drain the water away at the bottom of where your pool of water is, you need to get a wire coat hanger or similar to unblock your holes and then remove as much muck as you can :)
Awaiting Repair
#3 Post by Awaiting Repair »
Have a look here........
https://forum.triumphdolomite.co.uk/vie ... hp?t=16792
I would use something made from plastic to poke them out.
Keith
#4 Post by Toledo Man »
Such as a cable tie perhaps?
Bumpa
#5 Post by Bumpa »
Thanks for the link to that article Keith. I shall have to get a cable tie and have a go!
tamtrucks
#6 Post by tamtrucks »
i use air line and a hoover for those drainage holes/passages,work wonders
