How watertight is your roof and A post gutter ?
Richard the old one
#1 Post by Richard the old one »
With all the rain we have been having I noticed that a small amount of rain water was dripping onto my brown cars parcel shelf close to the door. Initially I suspected the windscreen had started to leak but when I looked at the A post gutter, I suspected that it could be creeping in via the metal join which is within the gutter. See the photo of the red car’s gutter. Between showers when the area had dried out I applied some black silicon sealant, see photo of brown car, and despite having many further very heavy showers I have not seen any further water entering the car.
I believe that the total length of the gutter, along the top of the roof could suffer the same sort of leak and allow water to enter the car. It could be the possible entry path for water into the boot of the car that I have not been able to trace.
The limited access will make it difficult to make a neat job and to produce a good seal but when we have a dry spell it will be something I will be attempting to achieve.
Have any other owners suffered this problem and have any suggestions of how to make a good job ?
GrahamFountain
Re: How watertight is your roof and A post gutter ?
#2 Post by GrahamFountain »
I certainly have a similar problem, though I still think it could be the sreen rubber (which is why I'm looking for a replacement). In my case the water is comming in what I think is too far from the wing to be from the A post gutter. It might be from water running down near the fuse box, however. Also, I had that wing replaced and asked if they'd look if there was a way in from under it, and they didn't see anything - I wish I'd been able to look at that myself.
It could be leaking in below the fuse box because the lip at the front of the plate on top of the bulkhead is a bit low in that corner, and I think if there's much water it may overflow that way.
I've tried a test or two, but there's always other stuff to do when it's fine, and it's hard to do a proper test when it's raining.
dollyman
#3 Post by dollyman »
Hi both, the easy way to trace a water leak is to use talcum powder :D The water will leave a trail straight to it. Check with swmbo first that it is not her best chanel......
GrahamFountain
#4 Post by GrahamFountain »
Not sure I get what you mean with the talc?
And everlybody knows talc is cheap. But how'd you know "She" had "A History of Adventure"?
Bumpa
#5 Post by Bumpa »
What he means is strip out the carpet and underlay and spread talc (or chalk lines will do as well) in the suspect areas, and wait for rain. The leak becomes immediately apparent as it washes some of the talc or chalk off.
On my Dolly I had replaced the clutch master cylinder and water exiting the drain slot from the heater plenum was getting behind the cylinder mount. I made up a thin gasket to seal the cylinder to the steel and no further problems.
dollyman
#6 Post by dollyman »
GrahamFountain wrote: Tue Jun 18, 2019 1:01 pm Not sure I get what you mean with the talc?
Groannnnnn :roll: :lol:
Tony,
GTS290N
#7 Post by GTS290N »
:lol: people have been flogged for less!
GrahamFountain
#8 Post by GrahamFountain »
Just ran another set of tests, which will probably need double checking and doing better; however, 4 litres of water down the gap at the base of the a post and nothing into the footwell. 2 liters into the middle of the cabin air intake plenum are and nothing. 2 litres down the back of the windscreen wiper motor and there's wet in the footwell. running down the inside of the bulkhead behind the accelerator peddle.
My only concern is I didn't wait long enough between tests, and it's from one of the earlier tests, but delayed more than I expected.
Richard the old one
#9 Post by Richard the old one »
Are you aware that it is a known problem that the over time the bulk head adjacent to the accelerator pedal can split and Alun has had some bits made up to strengthen the area. If yours has split it could be allowing water from one of the drains to enter the car.
GrahamFountain
#10 Post by GrahamFountain »
Richard the old one wrote: Tue Jun 18, 2019 9:56 pm Are you aware that it is a known problem that the over time the bulk head adjacent to the accelerator pedal can split and Alun has had some bits made up to strengthen the area. If yours has split it could be allowing water from one of the drains to enter the car.
There any pictures?
GTS290N
#11 Post by GTS290N »
GrahamFountain
#12 Post by GrahamFountain »
I shall go after tea and look. But that looks too low down to be from the plenum into the cabin, unless I'm looking at it wrongly.
#13 Post by Carledo »
There's a big oblong metal plate behind the wiper motor held to the plenum with 6 bolts and a whole wodge of sealant which dries out and cracks, could well be this!
GrahamFountain
#14 Post by GrahamFountain »
It is leaking from the engine bay - at least some water was draining out of the plenum and running along the rear right corner seam between cabin bay and inner wheelarch. As can be seen in the first pic, this is a bit rotten. That's the bonnet release cable running across and the side of the accelerator peddle on the left.
Some of the problem is shown in the second pic - water can just flow over the edge at the front of the plenum and run into the engine bay. I guess some of what rain gets in the plenum also ends up on the cabin floor too.
Not sure how I'm going to fix this. I may be able to glass down along the crack both sides. Maybe I can hammerite smooth the inside, then glass over that, and poor resin in the engine bay crack. My have to get another Big Boy FG kit. Not sure about fixing the gutter edge at the rear right corner of the engine bay. Looks like it needs unwelding and re-doing somehow.
GrahamFountain
#15 Post by GrahamFountain »
How do you stop water running out of the joint between the concertina tube to the air vent and the pipe from the back of the plenum?
Having fixed the problem with the bulkhead seam (fingers crossed), it seems clear that if the level of water in the plenum is high enough, and maybe if the angle the car's stood is enough, there's water coming through that joint.
