Correct Rubber Mats
Correct Rubber Mats
The mats in the green Dolomite that's for sale are the same as I have in mine, but if you look closely you can see they're not a great fit around the gearbox tunnel. My question is are they the correct Triumph ones for the Dolomite's.
This is the first photo I've seen with the same as mine.
- s-l1600.jpg (289.21 KiB) Viewed 1399 times
Club Membership No: 2017092
Re: Correct Rubber Mats
I've moved the thread here because it is Dolomite related.
No problemToledo Man wrote: ↑Tue Jul 30, 2019 3:33 pm I've moved the thread here because it is Dolomite related.
- tangocharlie1
No they are aftermarket, i had some also, replaced them for the tailored carpet type with the the Triumph Laurel emblem as they were a better fit, i thought the originals were built in to the carpet or maybe that is just early ones.
1973 Triumph Dolomite Sprint
1972 Triumph Stag
1973 Triumph TR6
1972 Triumph Stag
1973 Triumph TR6
afaik they only had the built in rubber mat on the driver's side.
So the ones we see there are aftermarket rubber ones, just with 'Triumph' added to them? They're some quality although a poor fit.
Was there not an option to buy genuine BL rubber mats to add.
- tangocharlie1
Not that i am aware of.
As Mart said the drivers side had a built in mat.
Rimmers do a reproduction here
https://rimmerbros.com/Item--i-RT1100BROWN
1972 Triumph Stag
1973 Triumph TR6
1972 Triumph Stag
1973 Triumph TR6
I have a pair of these mats and can confirm they were aftermarket as a while ago I traced the current owners of the brand in the hope the tooling still existed; sadly, it doesn't.
That's explains it for sure then.
What about a BL option in rubber, are you aware if these were ever available.
Thanks, but I was hoping to find a BL original set of mats to protect the carpet front and rear. Howver, the rear ones I have of these are a good fit though.tangocharlie1 wrote: ↑Tue Jul 30, 2019 10:22 pm Not that i am aware of.
Not a better pic by hand but one of mine came with these and are a good fit. These have Triumph on them. My Allegro has similar but with Allegro on it. Also a good fit.
- 20190731_220511.jpg (288.47 KiB) Viewed 1286 times
That looks the same as mine but just not a good fit round the tunnel.
if you own a Dolomite with a proper engine then they fit better as the tunnel isn't as wide
And Murdo's auto has a tunnel that is wider even than a manual Sprint one! Which doesn't help him find some mats that fit!
Just as an aside, the 1500, 1850 and Sprint autos all share the same tunnel as they cover the same transmission!
Does the Sprint share the box with any other models Steve?
That explains why my mats are are even poorer fit to the manual in the photo, never realised the tunnel was wider.
