Timing chain tensioner
canuck
#1 Post by canuck »
Have a 1977 LHD Sprint and timing chain getting noisey had it replaced a few years back A mechanic had a quick look thought it could be the tensioner that was not replaced at that time. So any advice on what one to buy as I see negative comments on the Roland.
RSi
Re: Timing chain tensioner
#2 Post by RSi »
canuck wrote: Wed Aug 07, 2019 8:22 pm Have a 1977 LHD Sprint and timing chain getting noisey had it replaced a few years back A mechanic had a quick look thought it could be the tensioner that was not replaced at that time. So any advice on what one to buy as I see negative comments on the Roland.
I think there's be a lot of discussion about tensioners, try a search?
Club Membership No: 2017092
Tony Burd
#3 Post by Tony Burd »
Robsport in the UK now sell a good tensioner for the Sprint. Do not buy Rolon, known to be crap and still being sold by some suppliers.
Aleco
#4 Post by Aleco »
Plus one vote for the Robsport Tensioner, if I remember correctly it's a jaguar xj one. It's what I fitted to mine after the Rolon one ate itself
longboarder
#5 Post by longboarder »
can I say as needing this too, how about timing chains? any good ones about?
canuck
#6 Post by canuck »
I will look at the Robsport one I did see the Jag one mentioned on checking on web. I may order a timing chain just it have on hand as none here in Vancouver
Aleco
#7 Post by Aleco »
I used a Wippermann chain from Jigsaw racing
https://forum.triumphdolomite.co.uk ... 9&start=15
trackerjack
#8 Post by trackerjack »
I have rebuilt quite a few sprint engines now and I often find that the original Renold tensioner is in very good condition and just because it has light grooving does not mean its useless.
I would not be in a hurry to replace perfectly useable parts. Chain guides and tensioners with grooves cause the tensioner to get nearer its limit and become noisy, so just reset the tensioner and many more quiet miles can be enjoyed.
#9 Post by soe8m »
That's my choice also. Better using good original used ones than new repro guides.
80Sprint
#10 Post by 80Sprint »
As mine was beyond use I went the Jag route also. Not a bad price either.
