Connecting a second router
#1 Post by Mad Mart »
I have an EE hub that replaced my old EE Technicolor TG589 router. Since moving house my hub is in a different room than my printer (which is non-wifi). Is there a way to use my TG589 as a repeater so I can plug a network cable into it and the printer to share it?
RichardHyde
Re: Connecting a second router
#2 Post by RichardHyde »
Yes you can do it I think.
I’ve got 2 EE Brightbox 2 routers which I’ve hardwired together.
Do a search for bridging routers. I’ll have a look too.
#3 Post by Mad Mart »
The routers won't be hard wired as they are in different rooms.
Galileo
#4 Post by Galileo »
IIRC they were the old Thomson routers in which case they don't have a WDS mode, which is what you need if you were hoping to make it a wireless bridge to use your printers ethernet. If I'm wrong and you find a WDS option in the web gui, that's what you're looking for.
#5 Post by Mad Mart »
Galileo wrote: Tue Sep 17, 2019 8:35 pm IIRC they were the old Thomson routers in which case they don't have a WDS mode, which is what you need if you were hoping to make it a wireless bridge to use your printers ethernet. If I'm wrong and you find a WDS option in the web gui, that's what you're looking for.
Thanks Galileo. After hours of looking and messing about I came to the conclusion that it doesn't support WDS. I'm assuming I can hard wire it?
Galileo
#6 Post by Galileo »
You could hard wire both routers and have one just acting as a WiFi AP.
I have some old Draytek Vigor 28xx routers lying around doing nothing but gathering dust, they do WDS and I'm happy to post one. Edit: FoC if that wasn't clear!
