Hi, does anybody know or could measure the dimensions of the speedo instrument thread eg thread, diameter and length ?
Thanks, Richard
Speedo nut size
- RichardHyde
Re: Speedo nut size
Richard
the nut comes with the speedo cable,what bit are you after
Re: Speedo nut size
It looks to be 5/8" UNC
Actual thread length is ~ 11 mm, but there's a further ~ 1-1.5 mm shoulder on the alloy spigot, there's then a further brass shoulder protruding from the alloy which is ~8 mm long and ~10 mm ø
