That is true up to a point in my experience.matt of the vivas wrote: ↑Wed Apr 29, 2020 11:12 pm My 1850 has an entirely standard cooling system and copes with traffic jams in 30 degree heat in the summer, never an issue. The standard cooling system is well up to the job as long as its well maintained, i change the coolant every other year.
I had an early 1850 several years ago. One day i made a return journey of over 110 miles.
After parking and getting out of the car I could a hissing noise....on lifting the bonnet a quick scan
lead me to realise that coolant was escaping from the join of the thermostat housing/inlet manifold.
Wrongly as it turns out, I thought the gasket had failed, when I went to fit a replacement
the actual fault became apparent, one of the thermostat housing bolts had corroded so much
that it was no longer clamping the housing and manifold together.
During the journey the coolant had dropped considerably (I think the radiator was still full but I couldn't
detect coolant in the top hose) but the temperature hadn't changed on the gauge
(there is a warning about this gauge reading scenario in the official workshop manuals).
My opinion is that I was lucky, very lucky, that no damage was done to the engine.
It was this experience that motivated me to look at improving the cooling system.
thanks,
