Hi are the front and rear door hinges the same for drivers side and passengers side , i know there different front and back
thanks Dave
P.S is it possible to repair the hinge when they wear ?
Door hinges
Re: Door hinges
I suspect the hinges are the same ( not 100 % sure ), but you can repair the hinges with new pins
https://www.ebay.co.uk/p/690957285?iid= ... gL9JPD_BwE
Re: Door hinges
Thanks think ive got 2 hinges to repair , 1 bent 1 wornmahony wrote: ↑Sun Jun 14, 2020 10:34 am I suspect the hinges are the same ( not 100 % sure ), but you can repair the hinges with new pins
Re: Door hinges
The rear top and bottom hinges are different to EACH OTHER and the rear upper hinge has an offset bolt pattern where it bolts to the post which makes it handed as well. The front hinge is all 4 the same (616393) rear hinge lower is 2 x 616396 and rear upper is 617431 (RH) and 617430 (LH)
HTH Steve
EDIT, I have quite a few of each in usable condition and several colours (no yellow ones though!)
HTH Steve
- lazeruspete
Re: Door hinges
Hi Steve,Carledo wrote: ↑Sun Jun 14, 2020 8:46 pm The rear top and bottom hinges are different to EACH OTHER and the rear upper hinge has an offset bolt pattern where it bolts to the post which makes it handed as well. The front hinge is all 4 the same (616393) rear hinge lower is 2 x 616396 and rear upper is 617431 (RH) and 617430 (LH)
HTH Steve
Just piggybacking on this thread a little bit.
I am sorting some hinges out for powder coating, however it has occurred to me that I need to dismantle them into their component parts so they dont get bunged up with paint.
Would you happen to have any tips on how to remove the pins?
TIA
Pete
viewtopic.php?f=19&t=23031
Proud TDC Member!
Proud TDC Member!
Re: Door hinges
lazeruspete wrote: ↑Sat Oct 24, 2020 4:53 pmNot if you are powdercoating them, spray the powder then open/close the hinges a few times (holding the bolt and nuts you've already inserted through one of the holes ) a few times to displace any powder on the hinge before you put them in the oven. as soon as they've cooked and cooled enough spray some releasing agent and light grease into the pin recess.
Re: Door hinges
I took mine in to a machine shop to be repaired, so didnt take mine apart,but the guy said they were hard to get the pins outlazeruspete wrote: ↑Sat Oct 24, 2020 4:53 pmHi Steve,Carledo wrote: ↑Sun Jun 14, 2020 8:46 pm The rear top and bottom hinges are different to EACH OTHER and the rear upper hinge has an offset bolt pattern where it bolts to the post which makes it handed as well. The front hinge is all 4 the same (616393) rear hinge lower is 2 x 616396 and rear upper is 617431 (RH) and 617430 (LH)
HTH Steve
TIA
Pete
