Door hinges
new to this
Door hinges
#1 Post by new to this »
Hi are the front and rear door hinges the same for drivers side and passengers side , i know there different front and back
thanks Dave
P.S is it possible to repair the hinge when they wear ?
mahony
Re: Door hinges
#2 Post by mahony »
I suspect the hinges are the same ( not 100 % sure ), but you can repair the hinges with new pins 😀
https://www.ebay.co.uk/p/690957285?iid= ... gL9JPD_BwE
new to this
Re: Door hinges
#3 Post by new to this »
mahony wrote: Sun Jun 14, 2020 10:34 am I suspect the hinges are the same ( not 100 % sure ), but you can repair the hinges with new pins 😀
Thanks think ive got 2 hinges to repair , 1 bent 1 worn
Re: Door hinges
#4 Post by Carledo »
The rear top and bottom hinges are different to EACH OTHER and the rear upper hinge has an offset bolt pattern where it bolts to the post which makes it handed as well. The front hinge is all 4 the same (616393) rear hinge lower is 2 x 616396 and rear upper is 617431 (RH) and 617430 (LH)
HTH Steve
EDIT, I have quite a few of each in usable condition and several colours (no yellow ones though!)
lazeruspete
Re: Door hinges
#5 Post by lazeruspete »
Carledo wrote: Sun Jun 14, 2020 8:46 pm The rear top and bottom hinges are different to EACH OTHER and the rear upper hinge has an offset bolt pattern where it bolts to the post which makes it handed as well. The front hinge is all 4 the same (616393) rear hinge lower is 2 x 616396 and rear upper is 617431 (RH) and 617430 (LH)
HTH Steve
Hi Steve,
Just piggybacking on this thread a little bit.
I am sorting some hinges out for powder coating, however it has occurred to me that I need to dismantle them into their component parts so they dont get bunged up with paint.
Would you happen to have any tips on how to remove the pins?
TIA :)
Pete
viewtopic.php?f=19&t=23031
Proud TDC Member!
TrustNo1
Re: Door hinges
#6 Post by TrustNo1 »
lazeruspete wrote: Sat Oct 24, 2020 4:53 pm
TIA :)
Pete
Not if you are powdercoating them, spray the powder then open/close the hinges a few times (holding the bolt and nuts you've already inserted through one of the holes ) a few times to displace any powder on the hinge before you put them in the oven. as soon as they've cooked and cooled enough spray some releasing agent and light grease into the pin recess.
new to this
Re: Door hinges
#7 Post by new to this »
HTH Steve
Hi Steve,
TIA :)
Pete
I took mine in to a machine shop to be repaired, so didnt take mine apart,but the guy said they were hard to get the pins out
