Competition spec dash varnish
GrahamFountain
#1 Post by GrahamFountain »
Has anybody successfully stripped the varnish off a 73 Doly dashboard, and if so, with what?
I have no idea what BL used, but the stripper I have, Bartoline TX10 from B&M's, has absolutely no effect, even left overnight; though it did the door caps fine. The orbital power sander also seems to be beaten by it. It really does seem to be absolutely hard as nails.
Aleco
Re: Competition spec dash varnish
#2 Post by Aleco »
Oddly enough I've just come in from the garage after stripping the varnish off the door cappings.
After trying a number of different approaches (sanding, scraping, chemicals, swearing, sanding a bit more, swearing and stomping off) I've found the panacea! A heat gun!
I used.the wide diffuser a low heat and gently heating and then it literally fell off with a scraper. It left the wood untouched underneath.
The door cappings were is pretty poor shape with multiple chips and flakes so this made it easier.
I guess the dash would respond as well?
For info I bought my heat gun from Screwfix for £25. It's the Earlex one with a kit.
GrahamFountain
#3 Post by GrahamFountain »
Perfect solution. Used the gun from the heat-shrink kit and it worked a treat. Thanks Aleco
Aleco
#4 Post by Aleco »
No worries. Pleased to help!
Alex
GrahamFountain
#5 Post by GrahamFountain »
At last, I found a reference for the dash and door cap colours for a 74 y.m.
marshman
#6 Post by marshman »
GrahamFountain wrote: Tue Jul 14, 2020 5:39 pm At last, I found a reference for the dash and door cap colours for a 74 y.m.
Any idea what the actual type of wood is that was used for the veneer? I need to redo mine at some point as the veneer is too far gone in places to just re-varnish/polish.
Roger
1971 Stag Auto White
#7 Post by Carledo »
marshman wrote: Tue Jul 14, 2020 8:57 pm
Roger
Someone will no doubt correct me if i'm wrong, but I seem to recall "American Walnut" being mentioned as the alleged wood for the veneer from the factory.
A photo, especially an old PR photo, is hardly a good guide to colour, so many things affect what you actually SEE and it could have been enhanced, tinted or downright airbrushed before it was even published!
GrahamFountain
#8 Post by GrahamFountain »
Carledo wrote: Tue Jul 14, 2020 9:39 pm
Roger
Yes, but it is at least a reference against which those with more perfect memories can offer positive opinion as to if it's a bit dark or a bit pale, etc.
GrahamFountain
#9 Post by GrahamFountain »
I expected the most obvious negative comment to be it's of an 1850, not a Sprint.
