Sprint LSV ..which fitting please?
shaunroche
#1 Post by shaunroche »
Hi chaps, ordered a Goodrich flexible brake line kit from Rimmer's yonks ago and have come to fit it to the LSV and see I need a male-male adapter to connect it up...could you recommend what fitting I need please?
Thanks!
Re: Sprint LSV ..which fitting please?
#2 Post by Carledo »
In all previous Gooodrich Sprint rear hoses i've bought, the adaptor fitting for the LSV has come with it.
But I have something that will probably suffice in the form of a M/M 3/8" unf fitting which is the standard bit between the 2 front-to-rear sections on all Dolomites.
#3 Post by xvivalve »
Yes, the Goodrich kits I’ve made up and supplied in the past had the correct fitting for the rear (slightly more expensive) hose. I suspect they’ve sent you three front hoses.
From some suppliers it’s prudent to check what has been sent immediately upon receipt…
shaunroche
#4 Post by shaunroche »
Thanks for the replies chaps, there are two pipes the same, longer length and the shorter third pipe has the swivel female port on one end so I think they are correct.
There was a connector in the box, but it looks like this..
new to this
#5 Post by new to this »
shaunroche wrote: Mon Apr 10, 2023 6:17 pm Thanks for the replies chaps, there are two pipes the same, longer length and the shorter third pipe has the swivel female port on one end so I think they are correct.
Shaun
I think your need an adapter with the round end on both sides or it may leak, why not take your hose to pirtek ( the hose people ) and get them to change the end, your have one less joint that could leak
shaunroche
#6 Post by shaunroche »
I think you need an adapter with the round end on both sides or it may leak, why not take your hose to pirtek ( the hose people ) and get them to change the end, your have one less joint that could leak
Dave[/color]
Could take it to Pirtek Dave but there's none round here, I was hoping that someone would tell me the thread of male male adapter, think it's 3/8 unf?
My issue is that I am unsure what creates the seal in the LSV...does the adaptor bottoming out in the bottom seal it or does it need a copper washer....
new to this
#7 Post by new to this »
shaunroche wrote: Mon Apr 10, 2023 6:53 pm
Dave[/color]
Shaun
Its the rounded end that makes the seal
or go to Car Builder Solutions and get PSBF04
#8 Post by Carledo »
My adaptor has the rounded end both ends. The flat end on that will go into the LSV but will need a copper washer and the rounded or tapered end into the hose.
shaunroche
#9 Post by shaunroche »
Thanks Chaps, that's sorted it - wasn't sure but can now forge ahead...onwards and upwards! :)
