Tyre Info
Tyre Info
Looking for some advice on tyre size for my 79 Dolomite 1300. Just taken possession and want to replace the steel wheels with the replica minilites from Rimmer Bros. Original Steels are 4.5J x 13 and the new alloys are 5.5J x 13 and trying to work out the best size tyre to go for that will be a straight forward fit without causing any issues. As I say the car is new to me and I’m sure other members of this forum will have the answer for me. Thanks in advance.
Re: Tyre Info
Sprint alloys are 5.5J
Std size tyres are 175/70 13’s
185/60 13 fit also without out rubbing.
1976 Taihiti Sprint
2024 volvo XC90 T8 Hybrid
2011 Landrover Defender pickup - twisted
2021 Toyota Yaris GR-Four
2015 Audi RS4 Avant (V8!!)
Re: Tyre Info
killysprint wrote: ↑Sun Apr 23, 2023 1:16 pm Sprint alloys are 5.5J
I used Dolomite Sprint wheels shod with 185/70 R13 Firestone S211 M+S tyres on my 1974 Triumph Toledo 1300 without any problems. They probably give a more comfortable ride than 175/70 R13 tyres and slightly better fuel economy.
Regards.
Nigel A. Skeet
Nigel A. Skeet
Re: Tyre Info
Got 195/60/13s on mine.
It sits a bit lower with gas shocks all round, but no rubbing, and no problems,
Richard.
Richard.
- 364AA811-88DB-4EED-93CC-3E516B608DBD.jpeg (136.38 KiB) Viewed 9336 times
Sprint, ;- DBL 532V
Re: Tyre Info
naskeet wrote: ↑Wed Apr 26, 2023 10:57 amkillysprint wrote: ↑Sun Apr 23, 2023 1:16 pm Sprint alloys are 5.5J
I used Dolomite Sprint wheels shod with 185/70 R13 Firestone S211 M+S tyres on my 1974 Triumph Toledo 1300 without any problems. They probably give a more comfortable ride than 175/70 R13 tyres and slightly better fuel economy.![]()
What is the wheel-offset of the 5½ x 13 inch, replica Minilite style wheels from Rimmer Brothers?
https://rimmerbros.com/Item--i-GRID008496
https://rimmerbros.com/Item--i-RT122955X13
https://rimmerbros.com/Item--i-RL147055X13
https://rimmerbros.com/Item--i-RL147055X13BLK
When I had 185/70 R13 Firestone S211 tyres on my earlier 5½ x 13 inch Cosmic alloy wheels (21 mm wheel-offset) the tyres rubbed on the outboard portion of the rear wheel arches when carrying heavy loads in the boot or rear-passenger seats, but this did not occur with the same tyres on 5½ x 13 inch Triumph Dolomite Sprint alloy wheels (35 mm wheel-offset).
If I had had 195/60 R13 tyres on the 5½ x 13 inch Cosmic alloy wheels (21 mm wheel-offset) the tyre rubbing on the outboard portion of the rear wheel arches, would probably have been even worse!
Regards.
Nigel A. Skeet
Nigel A. Skeet
Re: Tyre Info
Sprint wheels are a safer bet than the "fake minilites" that are available everywhere.
These wheels are mostly a product of John Brown Wheels and the largest ET/offset i've been able to track down (and i've been in touch with JBW) is a mere 14, compared to the Sprint ET of 35. Which places the outer rims in unacceptable proximity to the rear arch lips.
I actually have a set here, but in 14" diameter x 5.5j, that I bought for my Sprint, they fouled horribly so I had to take them off again and search elsewhere for suitable wheels. But they'd be just right for a small chassis car, Herald, Spitfire, GT6 etc, if anyone would like them, I can make you a good price!
Rimmers list them for the Dolomite range true, but they aren't well known for checking to see if the product they are offering will actually work on the car they are listing it for!
- shaunroche
Re: Tyre Info
Thread highjack alert!!
Just out of interest I'm looking at putting 195/55/14's on my race Sprint but was unsure what offset to specify for the wheels....will a 14" wheel with a normal sprint wheel off set at 5.5J fit? It's worth pointing out that all wings have been rolled and the rear arches pulled out a bit...I'm more concerned about the rear wheels rubbing on the inner arches......thoughts please
Re: Tyre Info
If you've rolled and pulled the rear arches, you can run a smaller offset. But as I said above, the JBW fake minilites only go down to ET14 which MIGHT just clear your modified arches. Extensive research i've done with a number of manufacturers and suppliers has not turned up ANYTHING in either a 14" or 15" rim with both the 95.25mm PCD and a Sprint compatible ET in the 25-35 ballpark. Sure, you can have them custom made, but the price is eye-watering!shaunroche wrote: ↑Tue Oct 31, 2023 10:25 am Just out of interest I'm looking at putting 195/55/14's on my race Sprint but was unsure what offset to specify for the wheels....will a 14" wheel with a normal sprint wheel off set at 5.5J fit? It's worth pointing out that all wings have been rolled and the rear arches pulled out a bit...I'm more concerned about the rear wheels rubbing on the inner arches......thoughts please![]()
If you'd like to try them for size, the 5.5x14 ET14 fake Minilites I have are all shod, currently with road legal (if a little old) 185/60/14s.
If i'd actually rolled mine, I might have got away with it. But as it was freshly painted I just removed a chunk of the double lip (as much as I dared) and it wasn't enough on bumpy corners, especially with a loaded boot and/or rear passengers. Something that wouldn't affect your race focused car!
In your position though, Id go for the MGF 15x6 ET27? rims with 195/50/15 tyres which I KNOW will go inside rolled arches, miss the inners (not by much, but enough for track work) and which are available in several styles, and are cheap and readily available. They also have a bit larger rolling radius than a 195/55/14 and will fill the arches better.
- shaunroche
Re: Tyre Info
Hi Steve, cheers for the reply!Carledo wrote: ↑Tue Oct 31, 2023 4:18 pm......If you've rolled and pulled the rear arches, you can run a smaller offset. But as I said above, the JBW fake minilites only go down to ET14 which MIGHT just clear your modified arches
In your position though, Id go for the MGF 15x6 ET27? rims ......195/55/14 and will fill the arches better.....
The tyres I'm looking at using are offered in 185/55/14, 185/60/14 and 185/55/15 so if you have a set of wheels that will take that size, they will certainly be worth a try.....we'll speak further on this!
I got two sets of 'minilites' from R an R alloys @13" x whatever the Sprint offset is (they are JBW wheels) and fitted with 185/60/13's fit perfectly.....up to a reasonable size, R n R can offer that wheel at the offset you specify and I don't remember there being any change in price for them....could you remind me what the Sprint offset is please?
Yes....
They Minator wheels from Rimmers are, having myself fitted them to an early 1850, a good choice.classicken wrote: ↑Sun Apr 23, 2023 12:41 pm Looking for some advice on tyre size for my 79 Dolomite 1300. Just taken possession and want to replace the steel wheels with the replica minilites from Rimmer Bros.
The track width is slighter wider (making the car more stable) and they comfortably clear
Trackerjack brakes.
I used 175/70 tyres as per a Sprint and felt no reason to be unhappy with this size.
No modification to the bodywork was required.
(From memory they have an ET25 offset)
Ian
Re: Tyre Info
Standard Sprint ET is 35. Besides the 14" fake Minilites, I also have around (maybe available) a set of MGF 15s currently shod with 195/50/15 Toyos and a set of wheel nuts that will fit either set of rims to 7/16" Sprint studs.shaunroche wrote: ↑Wed Nov 01, 2023 9:43 amHi Steve, cheers for the reply!Carledo wrote: ↑Tue Oct 31, 2023 4:18 pm......If you've rolled and pulled the rear arches, you can run a smaller offset. But as I said above, the JBW fake minilites only go down to ET14 which MIGHT just clear your modified arches
It seems if you have 13" rims, you can get close to a Sprint ET, it's only when you go up in diameter, as I've been forced to by my oversize TJs, that the problems start!
- shaunroche
Re: Tyre Info
Could you show me some pictures of the wheels in the arches please so I can see the clearance particularly the inner rear space between the wheel and body?.....that looks mint!
STEVE.....
So if I go for the 185/60/14 given that I can specify the offset and given that the tyre I'm looking at has quite a square edge profile, what sort of offset would we be looking at, do you think it needs to be greater than the ET14 you mentioned Steve?Carledo wrote: ↑Tue Oct 31, 2023 4:18 pm......If you've rolled and pulled the rear arches, you can run a smaller offset. But as I said above, the JBW fake minilites only go down to ET14 which MIGHT just clear your modified arches
Re: Tyre Info
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
- shaunroche
Re: Tyre Info
That's very useful, thank you!SprintV8 wrote: ↑Fri Nov 03, 2023 12:24 pm How to measure check offset ETC.
https://www.performancealloys.com/alloy-wheels-offset
Re: Tyre Info
If you are runing the same (5.5" wide) rim width as an original Sprint, just an inch bigger diameter, I see no reason to stray from the Sprint ET of 35. If this is not doable and bearing in mind your pulled and rolled arches, I'd say, without seeing it, a minimum ET of 25 should keep you out of trouble.shaunroche wrote: ↑Fri Nov 03, 2023 11:52 amCould you show me some pictures of the wheels in the arches please so I can see the clearance particularly the inner rear space between the wheel and body?.....that looks mint!
STEVE.....
But there really is no substitute for a physical experiment, I don't KNOW the ET14s won't fit your car unless we physically try them! I only know my road focused car, without proper rolling OR pulling the arches, didn't like them!
One final point i've not mentioned, if using the MGF type 15s, on the FRONT, the effective max profile my own Sprint would accept is xxx/55/15. This was with ride height close to stock, the tyre would catch the back corner of the spoiler halfway from central to full lock on 185/60/15s but clear on 185/55s. The 14s with ET 14 gave no similar problem on the front with 185/60/14 tyres. I ran the Carledo for many years on MGF 15s, shod with 195/50/15s all round, without issue, just the rear arches rolled.
