You gotta love CAD!
Nice work mate!
Nice work mate!
Today I've dry fitted the front wing with screws and sorted out the inner valance. Welded in the front valance and fitted the headlight mounting plate. Just got the eye brow to finish off on the driver's side and weld the wing on.
- IMG_20170730_144859.jpg (142.31 KiB) Viewed 40854 times
- IMG_20170730_144928.jpg (136.54 KiB) Viewed 40854 times
- IMG_20170730_144959.jpg (157.06 KiB) Viewed 40854 times
- IMG_20170730_145028.jpg (162.06 KiB) Viewed 40854 times
- IMG_20170730_145055.jpg (181.31 KiB) Viewed 40854 times
- IMG_20170730_145125.jpg (174.68 KiB) Viewed 40854 times
- IMG_20170730_145158.jpg (176.07 KiB) Viewed 40854 times
- IMG_20170730_145237.jpg (180.4 KiB) Viewed 40854 times
- IMG_20170730_145309.jpg (165.79 KiB) Viewed 40854 times
- IMG_20170730_145337.jpg (157.21 KiB) Viewed 40854 times
Last couple of pics from today's work
- IMG_20170730_150124.jpg (156.64 KiB) Viewed 40855 times
- IMG_20170730_150153.jpg (161.86 KiB) Viewed 40855 times
- IMG_20170730_150216.jpg (187.72 KiB) Viewed 40855 times
- IMG_20170730_150241.jpg (167.74 KiB) Viewed 40855 times
- IMG_20170730_150307.jpg (177.64 KiB) Viewed 40855 times
- Site Admin
Welcome to the Forum! Unfortunately the person who started this topic is no longer a forum member and hasn't been on here for nearly three years, so is probably not going to answer your question. However, if you stick around maybe someone else might be able to reply.
Last MOT expired 19 Nov 2017
On Sorn.
On Sorn.
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
212Hrs @31/12/2021
352 @ 28/11/2022
455Hrs @ 20/10/2023
565Hrs @ 07/12/2024
Member TDC no 0471
There are some pictures of the sump on page 1 of the thread. Maybe someone can identify what sort of is.
- Mazda 323 oil pan.jpg (11.07 KiB) Viewed 39986 times
So after many years I'm back on to getting the dolomite going. Unfortunately I left it too long sitting on bad ground and the underside has really suffered. I've managed to get the eninge running and checked drive train over and have acquired a new shell to transfer all the parts to. I will keep adding to this thread and hopefully people will keep enjoying it.
New and old
- 20230803_120314.jpg (137.58 KiB) Viewed 39578 times
Started to strip donor shell down. Front seats and carpets out. Heater matrix and gearbox tunnel removed. Handbrake lever removed. Front half of wiring loom taken out. Also got most of the parts out of the engine bay. Just clutch master cylinder and insulation to go. There's a small rust hole under where the brake master cylinder is and an on old repair on the throttle pedal mount that's going to need some attention.
- 20230803_135127.jpg (84.77 KiB) Viewed 39563 times
- 20230803_131637.jpg (87.48 KiB) Viewed 39563 times
- 20230803_131619.jpg (84.04 KiB) Viewed 39563 times
- 20230803_120512.jpg (78.36 KiB) Viewed 39563 times
- 20230725_190354.jpg (148.02 KiB) Viewed 39563 times
- 20230725_190345.jpg (126.25 KiB) Viewed 39563 times
A bit more progress on the green shell. Got it pressure washed and finished stripping the engine. Git a few holes in the firewall and left hand side behind strut mount. Left hand bonnet mount also needs a repair but apart from that engine bay is pretty solid.
- 20230807_192322.jpg (148.62 KiB) Viewed 39538 times
- 20230807_192353.jpg (163.74 KiB) Viewed 39538 times
- 20230807_192417.jpg (83.35 KiB) Viewed 39538 times
- 20230807_192440.jpg (86.07 KiB) Viewed 39538 times
- 20230807_192555.jpg (86.78 KiB) Viewed 39538 times
- 20230807_192612.jpg (80.21 KiB) Viewed 39538 times
That's a real shame given the work you put into itPhilgroom wrote: ↑Sat Aug 05, 2023 8:43 pm So after many years I'm back on to getting the dolomite going. Unfortunately I left it too long sitting on bad ground and the underside has really suffered. I've managed to get the eninge running and checked drive train over and have acquired a new shell to transfer all the parts to. I will keep adding to this thread and hopefully people will keep enjoying it.
Its just going to be a lot less work to get the green shell repaired than the brown one. It did take me ages to decide to replace the shell as its almost like getting a whole new car with different personality.xvivalve wrote:That's a real shame given the work you put into itPhilgroom wrote: ↑Sat Aug 05, 2023 8:43 pm So after many years I'm back on to getting the dolomite going. Unfortunately I left it too long sitting on bad ground and the underside has really suffered. I've managed to get the eninge running and checked drive train over and have acquired a new shell to transfer all the parts to. I will keep adding to this thread and hopefully people will keep enjoying it.
I've got the front and rear windows out and the chrome off the car without damaging or twisting it so hopefully it will go back on. Only a bit of surface rust around front window. Also put my best boot lid on and adjusted to fit properly.
- 20230818_184452.jpg (73.98 KiB) Viewed 39474 times
- 20230818_184502.jpg (73.89 KiB) Viewed 39474 times
- 20230818_184517.jpg (74.15 KiB) Viewed 39474 times
- 20230818_184526.jpg (67.37 KiB) Viewed 39474 times
- 20230818_184539.jpg (69.76 KiB) Viewed 39474 times
- 20230818_184550.jpg (66.66 KiB) Viewed 39474 times
- 20230818_184602.jpg (67.62 KiB) Viewed 39474 times
- 20230818_184613.jpg (66.23 KiB) Viewed 39474 times
- 20230818_190610.jpg (71.63 KiB) Viewed 39474 times
