Sound deadening...
Laverda
Sound deadening...
#1 Post by Laverda »
Does anyone have any experience using self-adhesive sound deadening material such as eDead?
As my Dolly will need carpets anyway I'm wondering whether adding sound deadening is worthwhile. The stuff sounds great, if it works as the sellers claim!
David6214
#2 Post by David6214 »
Sound deadening would be a good idea (although I kind of like the sound!) You will need to modify a carpet for the centre tunnel. I had someone who works in carpeting look at the tunnel and he was recommending a stick on carpet. Showed me some, looked impressive.
Lewis has put some acoustic deadening in the car at the moment, does a good job , he did give me the name but it escapes me at the moment.
I have some carpets here, we can do a trial fit of the standard ones if you like!
Laverda
#3 Post by Laverda »
Hi David,
trial fitting sounds good, thanks. Didn't realise the centre tunnel was modified, good job you mentioned it before I bought a carpet set!
I need to get the car habitable for the wife & kids or they'll moan, so carpets & rear belts are a priority.
I'll also fit the back box, makes it more of a Q-Car & stops me getting pulled!
Really looking forward to this Saturday!
David6214
#4 Post by David6214 »
Rear seat belts are easy, the achorage points are already there. There are floor mats in it at the moment, but carpets would be a nice addition....
Tunnel is modified to fit the LT77 box...exhaust sweeps through there as well
tinganting
#5 Post by tinganting »
i find masking tape on there mouths will work.. means you can hear that lovely engine noise. other than that i think your pretty much stuffed unless you can divorce them??
#6 Post by xvivalve »
I would not use self adhesive sound deadening; there are various ways that water gets into dolly shells and having it permanently trapped between insulation and metal would be baaad
Autonet7
#7 Post by Autonet7 »
tinganting wrote:i find masking tape on there mouths will work.. means you can hear that lovely engine noise. other than that i think your pretty much stuffed unless you can divorce them??
Gaffer tape's much much stickier and seals the edges better. Removes those 'tashy bits when they rip it off too :twisted:
Lewis
#8 Post by Lewis »
Problem with carpet underlay is it retains moisture, so if it gets wet you create an instant rust hotspot.
Laverda
#9 Post by Laverda »
Good point about trapping water, hadn't thought of that, might still do the centre tunnel & upper part of the bulkhead.
eDead also do a waterproof sound-deadening liquid, $45 a gallon, £70 a gallon over here :shock:
triumphdolomiteuk
Site Admin
Site Admin
#10 Post by triumphdolomiteuk »
Lewis wrote:Problem with carpet underlay is it retains moisture, so if it gets wet you create an instant rust hotspot.
Too right! When I had my Spitfire restored a few years ago I fitted a sound deadening kit. Not realising how much moisture could be trapped, I put the car away for the winter....
It was an expensive mistake :cry:
bifold
#11 Post by bifold »
What you need is carpet underfelt,this is what I used under pub carpets,(all the beer spills)it dont trap moister and If you get a choice bonded is best, cuts very clean,most rolls 54 inchs wide, :D
alolympic
Re: Sound deadening...
#12 Post by alolympic »
I have experience of using a different type of product for insulation that may be of interest.
It may seem a bit more expensive but it is a lot more versatile and very effective.
It is a sprapy, or paint on, product that you can apply to internal and external surfaces called LizardSkin.
You can buy it in the UK from Agriemach Ltd (that are very good for all types of insulation).
Here are some links -
http://www.lizardskin.com/
http://www.agriemach.com/
It is made in the US and is very popular over there with Hot Rodders. The great thing about it, is it lighter than adding loads of underlay but can added to external surfaces, wheelarches, under bonnet etc. You can also paint over it. Don't be put off by the advice about spraying any larger areas, rather than applying with paint brush, I painted my whole interior and was fine.
I have used it on a kit car and will apply it to my Dolly when I get one.
Oh and by the way....no, I have no relationship with either company mentioned, just sharing a secret
cheers......
Dollyboy
#13 Post by Dollyboy »
ive recently had a few sheets of terodem from loctite, its meant to stick on under your bonnet, and indeed it will, but ive also done glorias tunnel with it. sticks on well, but how it is with damp retention - no idea. based on the sort of foamy material it is, i dont think it'd hold much damp.
i'll be repainting the front footwells anyway and they're solid to start with so lets see how gloria is in a couple of years. still pretty solid id wager...
1300dolly
#14 Post by 1300dolly »
did laverda ever sort out the carpet and has he still got the car?
